2 post car lift...
bigbert
Uist
Ready to install a 4000kg 2 post car lift and the concrete is too thin and not the correct psi
Is it better to have 2 pads cast at 4 wide x 5 long x 2 feet deep for each post
Or
4 wide x 16 long x 1 foot deep spanning the two posts
Not sure what is under the existing slab but I think it would just be earth.
Thanks
bigbert
Uist
Hi there,
If I went across with the pad how far past the post would I need to go on either side, a good foot past either post looks good.
Thanks.
CraigStu
Blacksburg, Va
I'd go all the way across so you have one large pad. When you cut out the existing rectangle and start digging, dig back under the edges of the existing floor 6-8 inches so the new pad actually flows underneath the existing floor.
pattenp
Virginia - USA
The width of my 9000lb 2 post lift is a little less than 12ft and the manufacturer calls for a pad 14 feet X 4 feet X 12 inches thick keyed into original slab.
SJW
Thousand Oaks, CA
Who is the lift manufacturer? What are your actual concrete specs?
Many lift manufacturers whose specs I've looked at -- BendPak and Rotary, to name a few -- call for from 4 to 4.5 inches of concrete depth, 3000 psi for up through a 10,000 pound, two-post lift. Mohawk calls for deeper and stronger.
To answer your original question, having a single long slab is stronger than two pads, in general. Make sure, as pattenp points out, to key the new slab into the existing slab.
As for width of the slab, I would go at least two feet wider than the full width of the lift, which would probably be back of base plate to back of base plate.
bigbert
Uist
wow this slab is getting bigger.
Have looked at other people's slabs / pads they have put in and they are not that big at all.
Lucid Moments
Gainesville, Ga
The earth's crust is only about 3 to 5 miles thick depending on your location. That is barely thick enough to be truly safe. You will also need anchors that extend all the way through the crust into the mantle.
bigbert
Uist
Sounds like I maybe should get the floor torn up and get it re poured again to a 4" slab with fibre through it. Or sell the lift and go back to crawling under everything again...
rburke65
Canfield, Ohio
Mohawk has a good pictorial and specs on their web site. But I’d do the 4’x10’ single pour. Rebar. Fiber won’t add to the quality
Lucid Moments
Gainesville, Ga
TBH I wouldn't go to either of those extremes. Up to a point the more concrete you have the more secure it will be, but if you cut out a section maybe 1 meter wide by 2 meters long where each post is going to be, and dig under the existing slab a little it should be more than stable.
Some people on here tend to go to extremes.
