MCMDave
I don't attempt to make a living at it, but I like restoring furniture. Occasionally, an upholstered piece requires buttons made of the same upholstery fabric. While small hand operated gadgets can be had in the fabric department of department stores and shops, they are good only for thin fabrics. I have enough pieces of furniture now that need buttons, that I decided to look for a button press. I acquired this from a seller on eBay.
These operate a bit like a small arbor press. It requires two dies of the size button you want to make and that are sized either for light to medium fabrics or medium to heavy fabrics. The press can also be used for the fabric cutter. I had an old arbor press, but decided to use that one for the cutting operation, with a vintage button press to make the buttons. I didn't think to take a before shot of the press I already had. They both cleaned up nicely. When I find an old stand grinder I want to pay for, I'll buff the unpainted parts of these. What compound(s) do you recommend for steel?
What do you do with your arbor press?
