DeWalt Breakaway Sawzall Blades
Farmall450
Marengo, Illinois
That's a new one. Not a terrible idea, ig, if you haven't bent it first. :bounce:
https://www.dewalt.com/whats-new/breakaway-blades
I suppose if you cut a lot of ~2" or less stock with your reciprocating saw, it would be pretty useful.
IG I'm living under a rock, or rather Farm & Fleet doesn't carry them, b/c I haven't seen these. Just something interesting I saw on youtube of all places.
LXCam
Real men don’t depend on the shoe to stay in the cut!
F
Farmall450
Marengo, Illinois
Milwaukee Blades.
There is no substitute.
So if the Dewalt sticks on the upstroke, will it just completely break in half now? Awesome. Lol
Lenox smoked Milwaukee torch on some 3/8 plates I was forced to sawzall into manageable chunks. Same TPI...maybe it's b/c I was using a 20v sawzall :bounce:
Idk, they show a bunch of guys saying they don't break, that was a concern of mine too but it would take a shear, not a compression. :dunno:
GirlnAgarage
Texas
Interesting...makes sense, break off the used blade, pop it in again. But then I think, why not just make a pack of short blades? (Dewalt fan btw)
I use Lennox.
Super Mech
Bronx,NY
A little gimmicky if you ask me. Maybe they will work with low power saws, my Porter Cable saw bends almost every regular thickness blade I put in it pond before the teeth wear out. Then again most of my cuts are at awkward angles. Might work for cutting small stock clamped this n vise.
mmb617
PA
If I didn't need the longer blade I'd be using a shorter one in the first place, so what good would that do me? Just a gimmick with no real use in my opinion.
DFB
Southern VT/Western Mass
Solution looking for a problem
I guess maybe
Ya seems the need is to just buy a shorter blade :D but being that 6 inch blades are most common and most often those material cuts pipe, rod and tube stock only often wears down that first two inches when using the shoe plate to stay straight , seems like an okay idea :dunno:
FSrepair&fabrication
maryland
when i use a sawzall its mostly for demolition work, i think i would get the blade pinched and break it way before i would wear the teeth off
mike93lx
Richmond, VA
These have been out for a while and are pretty durable. They can be flexed like a regular blade and take some effort to snap off.
That said, my blades are almost all Lennox.
F
Farmall450
Marengo, Illinois
I was amazed with that sample Lenox. I'll def buy some of those if I can get a better rate than Milwaukee/DeWalt.
One of the few times I got a sample product that would actually make me by more.
neophyte
Pennsylvannia
I use Lennox.
Dewalt and Lennox are both now owned by Blak&Decker.
If the manufacturing facilities have not been combined yet, and are both under capacity, then they likely would be combined at some point, although I wouldn’t be surprised if B&D was having someone else make their blades to begin with.
As far as why a break off blade makes sense,
Reciprocating saws with adjustable shoes, but where you need to cut with a short blade.
You cut with the saw shoe extended fully, so you just use the front section of the blade.
When the front section gets dull, you snap blade off, and retract shoe as far in as possible.
You can use the blade like a shorter blade, where having extra blade length doesn’t work for clearance or safety reasons, but you get double the blade life essentially.
The alternative would be to use a grinder to cut down the blade to a shorter dimension, which is best done with a clamp or vise, and is a pain on a jobsite.
Also, in a pinch you can likely use the breakoff blades to cut thicker material, instead of having to keep both longer and shorter blades.
Another thing is blade cost, at least for the consumer, is usually per blade, and not per blade length.
Longer blades usually cost more, but usually not twice as much as a blade half the length.
I’ve actually considered just purchaseing bulk packs of reciprocating saw blades rather than smaller packs of shorter and longer blades, because the bulk pack price was less than the price of buying a smaller pack if short blades, by a decent amount.
F
Farmall450
Marengo, Illinois
I think it's a pretty good idea, if you're cutting sub 2" metal stock/pipe all day in and out. Get twice your money out of one blade that only costs a little more.
ChrisLS8
Milwaukee Blades.
I never thought they were anything special. I stick to Diablo for pretty much all things cutting or sanding related
cheechi
Triad, NC
seems like a good excuse to buy a portaband. Either for the actual cut or to shorten the sawzall blade to fit.
For sawzall blades, I like Diablo, Swiss made Bosch, then US made Dewalt & Lenox (I guess now the 'old' Lenox).
Milwaukee's short EMT blades are nice, the rest are just ok.
sk farmer
nd
I buy long blades and then just cut the shape and punch a new hole in it if I break them
oh yeah? well i sweep abrasive dust off the floor and make new grinding wheels out of it!
kidding of course.:lol_hitti
too bad milwaukee didn't come up with this, then it would be awesome! they are the only ones that have new ideas and or at least good ideas according to the fan boys.:spit:
F
Farmall450
Marengo, Illinois
Yeah, honestly. :shocking:
Apparently you aren't aware that Milwaukee makes the best-est of every tool know to man...:lol:
I suppose we've always known China was winning.
mike93lx
Richmond, VA
So every time I bend a blade, which I would normally bend back into shape I will end up with 2 small blades, lame. Guess the DeWalt engineers can not design a better saw then Milwaukee, so they are trying the blades ... just another failure.
They are pretty tough to snap. Not flimsy at all
F
Farmall450
Marengo, Illinois
Lol, so you haven't used them either? :shocking:
