Airtherm heater units
Ralphxj
NE Ohio
I picked up 4 of these Airtherm HR55 W heaters over the weekend. I have an outside wood boiler and will be adding heat to the shop for next winter. I'm told they were used to heat a 5000 sq/ft area, but the guy didn't know anything else about them. Does anyone have any info on them? What is the BTU rating? What might they be worth?
HoosierBuddy
Southern Indiana
I don't think anyone will be able to exactly answer your question.
Hydronic heaters output is based on the water temperature drop through the unit. That in turn is based on the inlet water temperature, the water flow and the ambient temperature.
You add to the fact that a quick google search didn't even show that model listed on Airtherm's site anymore and you are posing a bit of a head scratcher.
Looks like a unit a bit larger than that can put out around 40,000 BTU's under the right circumstances. That's their 062 unit they are currently making with a 1/20 HP motor. Your motor is a bit larger than that it looks like but that might be a good rough estimate...but like the guy you bought them from...I really don't know either. Look like nice units to me though.
Should be a way to make them work for you.
Phil
R
Ralphxj
NE Ohio
Thanks. Hoping 1 or maybe 2 will heat my 24x36 shop. Just need to insulate it and run the boiler lines. The guy I bought them from was a contractor doing the demo for a remodel. He just saved them from the dumpster.
