In the winter I don’t drive anything but my truck except for when my wife lets me occasionally drive her car. It is comfortable, does everything just fine but it is big and heavy (slow!) with a transmission that never does what I want it to. One of the things that makes Wisconsin winters feel so long to me is a lack of driving something fun. Don’t get me wrong it was always a very nice vehicle…just not fun. With the warranty now expired it was time to modify the truck to be what I wanted it to be. The last time I modified a truck for performance I put a ported intake and throttle body on my 1995 Silverado. It didn’t help at all ha.
I decided bolting on some form of forced induction was going to be the best plan. Being a truck I wanted to go with a positive displacement blower for low end torque. As a bonus I have never had a PD blower before. I was shopping options in that space and decided on the new Edelbrock EForce TVS2650 based kit. It uses the new 2.65L Eaton rotors used in the C7 ZR1. They had a sale on them on Summit in September so I jumped on that knowing I wanted to supercharger the truck before winter. My wife and I took the truck on vacation to Tennessee and about half way through started filling up with 93 octane to get all the 87 out of the fuel system. Once we got home I got to work.
Thank you to jbmatth in post 249 for the suggestion to remove the front wheels to drop the truck down lower! I can’t believe I never thought of that! I also made a step stool out of an engine crate ha.
I couldn’t work out a way to lift the supercharger into place by hand even with a friend or two helping but fortunately there was *just* enough room to get it in with the engine crane. The fuel line feeding the high pressure fuel pump under the valley cover is really in the way since it also has to slide under the cowl but eventually got it squeezed in there.
The instructions were 110% useless for this step. They were clearly for a different (probably older) kit that is very different and they make no sense at all for this step. The rest of them were fairly coherent (wiring, intercooler, lines etc). I even took the time to e-mail them corrected instructions and they ignored me. I just checked now and it looks like they finally updated the instructions in December.
Even the new instructions skip over how you are supposed to tighten the bolts. I’ve got a lot of tools and the only way I was able to tighten the bolts was to remove the coil covers, coils, and valve covers which gave me just enough room for a wrench.
Next up is intercooler:
Done!
This kit came with a tune which I didn’t have high expectations for. The engine ran fairly well but was straight up dangerous at wide open throttle (not nearly rich enough to be safe in a heavy vehicle under boost in my opinion). Put a wideband on it and as you can see in the pic it is commanding a ~11.1:1 AFR ratio but delivering closer to a 12.5:1 AFR. You can see 7 degrees of knock retard which occurred lower in the RPMs and 1 degree in this screenshot.
I switched to tuning with Lambda instead of AFR but the idea is the same. You want your actual EQ ratio to be as close as possible to commanded. You’ll see this cleared up the knock retard since the extra fuel helps keeps cylinder temps down. If you've got a real keen eye you'll see the truck is commanding 0.789 λ in both screenshots. A before and after if you will.
The Edelbrock tune made no changes to the transmission tune and it shifted like absolute garbage…much worse than it ever was before. I put in an aggression transmission tune and it actually made it shift significantly smoother. Go figure.
Am I happy with it? Hell yes! My mileage dropped from ~16mpg to ~13mpg and I have to run premium now but hey that's how it goes. With boost it is like a switch from every other truck to something special. It will never be as fast as summer toys but it puts a smile on my face and launching it in 4wd is absolutely amazing! The transmission actually behaves itself now. 8 months later I’m still tweaking the tune here and there but should have that sorted out soon. Then I can get it on a dyno to see if it manages the ~480whp they claim.
-Hillrod
