Modern suspension grease zerks....size?
nmantas
Downriver Detroit
Stupid question of the day.
Since all modern parts are metric, are grease fittings typically metric? If so, does anyone know the popular size of the little self tapping grease fittings that you spin on tie rods, ball joints, bar links for passenger cars/trucks?
BDT/NWMN
Erskine, Mn
I have both sae and metric grease fittings in threaded, drive in, and self tapping versions.
Add the straights, 45, and 90 degree fittings. That is 18 possible versions that come in multiple sizes.
I don't think there is anything stupid about the question at all. I am looking forward to reading the multiple answers.
:thumbup:
matt_i
SE Michigan
I just bought a ac delco ball joint and messed up the threads. It was 1/4-28. Some are 6mm - 1.00
These are my experience, but from an industrial setting, have assortments of both 1/4-28, M6 x 1.0 and the pipe thread NPT 1/8-27 threads for various OEMs machinery some of which are euro.
N
nmantas
Downriver Detroit
My issue is that I have two bar links that have two fittings each and after a few years only one works as it should.....the other ones need an adjustment on the grease gun tip then it goes on and you can't get it off and so on. Its the only fittings on the car and geez I never had issues on any other cars. Thinking of just replacing them with known quality because greasing four lousy fittings should not be a chore.....but you'd think aftermarket AC Delco 'professional' parts would be decent.
MagnusM4
Wisconsin
I installed some Moog ball joints in my truck and the zerks were either 6 or 7mm, I can’t remember which.
rlitman
Long Island
That’s the problem that the Lock-N-Lube was invented for. It releases with the press of the lever, and locks on solid at all other times. I can’t begin to describe the amount of frustration it has removed for me.
WagonHo!
Albuquerque, New Mexico
Lock n lube, Zoro and GFD the green anodized one.
bwringer
Indianapolis
Very, very few OEM parts on passenger vehicles have grease zerks. And if they did, they would very likely be metric.
Aftermarket parts, it's a complete crapshoot what they're going to screw in there.
Or, maddeningly, what they're going to leave rolling around loose in the box for you to attempt to insert in a poorly tapped or untapped hole (lookin' at YOU, Moog, or whatever the hell is inhabiting Moog's corpse nowadays and peddling low-rent Chinese shite under that once-proud name).
