remagenman
- Joined
- Oct 30, 2011
- Messages
- 439
So, I want to power the shed from the main panel using one 12/3 UF-B cable but as 2 circuits and this is what I've learned so far:
-you can only run 1 12/3 cable to shed from panel (panel is about 25 feet away).
-I can do a dual circuit with the one cable by doing a MWBC using a 20A 2-pole breaker.
-I will only run some LED shop lights, radio (on most time) with the occasional band saw, table saw, planer, all 115V (occasionally). I will probably run a Shop-Vac while running one of the tools with the lights and radio on.
Is this setup good? I already setup 220V outlets for whatever needs to be ran 220V outside the garage so I dont need 220V in the shed.
Thanks. Here is a picture of what I want to run as a MWBC.
