OEM Low profile socket sets
Handyandy23
Ontario, Canada
+1 for the Astro Nanos. Impact rated and have a 17mm hex on the outside so you can use a ratcheting wrench instead of a ratchet for even lower-profile use.
I use them on the Nano impact gun rated at 500 ft-lbs and the Nano sockets have held up fine.
AGuinn
West TN.
I have the metric OEM set, and for $15 it's a no brainer. They come on a nice extruded aluminum rail and the matte finish and knurling are much nicer than the price would indicate. I use them if I need a 12-point socket or tight space to work in. I don't have them in front of me (I can check tonight), but iirc they are 1/4 - 3/8 inch shorter than the short GW equivalent. The Astro's look nice as well, and cover more sizes, but I have run into some instances where the external hex would interfere with the surroundings.
Old-Soul
Alberta, Canada
I have them in both red and blue and I really like them (for the twice I've been able to use them).
Aluminum rails are a nice touch and like AGuinn says, for the price can't go wrong.
Mr_B
Reading
oem sockets are a hidden gem considering prices and decent design.
you can find that stubby set for 11.99 if look .
2ndGearRubber
Pittsburgh
That's why I have them. My main use set is snap on low profile, but these are quite similar and 12 point. In super tight spots in can be easier to get a 12 point socket onto a fastener than a 6.
AGuinn
West TN.
Measured the OEM set vs a short GW set, a 10, 13, and 19mm as representative sizes (common and largest) for comparison. Don't take the numbers as absolute, as the calipers I was using aren't my good set and have been dropped a few times - the repeatability is + or - a few thou.
GearWrench 10mm 1.005", 13mm 0.980", 19mm 0.990"
OEM Low Pro. 10mm 0.788", 13mm 0.795", 19mm 0.871"
bonneyman
Desert SW
That's what I was wondering. Geez, using them that way is even more compact than a SALTUS wrench! :thumbup:
JBradley500
I was going to recommend the Mastergrip 35 piece kit that is the same as the chrome set in the first post but with a lot more pieces but I can't find it for sale anywhere right now. I'd keep an eye out for that.
nmantas
Downriver Detroit
Side note, I have read many times by users and even the Astro rep that although the Sunnex and Astro set appear identical....each individual Astro socket is considerably heavier because they dictate a different alloy (assuming to be stronger).
Astro_Pneumatic_Tools
South El Monte
Same alloy, and if they were a different alloy they would probably end up still weighing the same as well if the designs were the same. The reason for the weight increase (and it's not a significant weight difference) is the amount/thickness of inner material between the square and hex broach ends on our sockets.
We test our 3/8" sockets with 1/2" impacts, and torch heat the fasteners during tests as well to get the sockets hot and thermal cycled. We found this inner thickness was cheap insurance.
BarryWells
In the mountains
COOL. You guys should do a few videos. Long time mechanix know you have good product but newbs are usually clueless.
nmantas
Downriver Detroit
Thanks for clarifying....they are on my list to buy.
