Should I buy this compressor?
brianpgriset
Beaumont, TX
I have the chance to buy a Bel Aire 318VE air compressor for a bit under $1000. Thats a 7.5 HP compressor, makes 25CFM at 175 psig and 32 CFM free air, which is probably enough for me for a long long time. One thing has me hung up though, the motor is a 3450 RPM, so my guess is the pump RPM is somewhere in the 1300 range. Faster (and louder) than I'd really like. I was really eying a new Quincy 5HP from Northern Tool new for 1700, but it makes around 7 CFM less, but spins slower, quieter and would be new.
Could I just get a smaller pulley on the motor and turn the pump slower to decrease noise/increase life? I know I'd loose some CFM though...
The used Bel Aire is very clean.
Any opinions?
brianpgriset
Beaumont, TX
BTW I want this to be the "last compressor I'll ever buy". I have a small sandblaster and plan on upgrading to a medium sized one soon, also will be running body tools like a DA sander on occasion, but not all the time.
94cobra2615
For that price you could get a 4 cylinder EATON that would kill the Quincy and the bel aire. AND it spins around 600 rpm......I can talk on a cell phone beside mine. They are on sale till the end of February.
BUT I am biased:bounce:
Specs on mine: 4 cyl, 2 stage, 34 cfm @ 0psi, 28 cfm @ 100psi, 26 cfm @ 175psi, 7.5 hp.
The bel aire sounds nice for the price though.
morehead
southwestern ontario
I would like to replace my compressor because it runs @ 3450,it is built by a local company I bought used $450 has stood up fine but is too LOUD:shocking::lol_hitti.Some older stuff runs nice & quiet but I would stick with a unit that runs @ about 1750rpm.
Just my 12 cents worth.
irisservice
NYC,New York USA
I dont see a 4 cylinder only a 3...
http://www.eatoncompressor.com/catalog/item/504747/6112301.htm
PurdueSD
Indiana
I am am really really happy so far with my 5hp/ 80 Gal Quincy.
I found it a a local farm store (Rural King) much to my surprise. I waited for them to run one of their wacko good sales and picked it up for $1200 brand new. This was a couple years ago, but i think it was retailing for 1600-1700 at the time.
I will tell you that it is the quietest large compressor i have ever been around right out of the box. I had plans to enclose it in a closet under the stairs, but after firing it up, it wasn't loud enough to bother.
I don't have a sandblaster yet, but it laughs at die grinders.
brianpgriset
Beaumont, TX
http://www.belairecompressors.com/p_piston-2stage-electric.html
Here is a listing of their models, the 318VL is down the list (7.5 HP).
If I could pick up the 5hp quincy for that price I'd do it, does Northern Tool ever run sales on those compressors? Or a good coupon? Will that be enough to run a medium sized blast cabinet? I told myself going in I wanted a 7.5HP outfit.
I thought for a long time about the eatons, I just wish A) I could get it local and B) it was USA made.
94cobra2615
The belair is almost usa made. The pump unit is made in italy from what i can tell. It's all ASSEMBLED here though.
rwhite692
Central Valley, CA
You simply cannot compare anything that Eaton sells, with a Quincy.
All of Eaton's pumps are Chinese-made. Not to say they aren't "good" pumps but the Quincy product line is in an entirely different league and is a US-made industrial-duty pump designed for long service life and high duty cycle. Apples and Oranges.
dfndr
Fresno, CA
rwhite, are the entry level Quincy's like the ones on the net that you can get for about $1250 delievered as good a quality as you say the others are or is it just like a "homeowner" model of lesser grade? I am really interested in this stuff as I want a good compressor but can't justify a huge price for weekend garage work. I notice that the Quincy runs pump at over 1300 rpm. Is this too loud a pump when all is said and done? Thanks.
Dave Heacock
Santa Clarita, Ca
Just a quick note, when looking at compressors be aware that the pump size is a huge factor beyond just the H.P. of the motor that turns it. Several compressor manufacturers have fast compressor models that put a larger H.P. electric motor on a smaller pump and spin it faster. This is a recipe for long term failure. I see many in the thread are noting RPM and are informed, but I thought I would just put that out there for the newbies who might be shopping for a compressor. Also when comparing CFM between different brands be sure you comparing at like delivery pressures.
