how do you cool bathrooms w/ Mini-Splits
mike_s
I've got a 24x30 garage. I want to put a mini split along the back wall. Thinking a 24,000 btu.
My question is how do I cool my small 5x8 bathroom with a mini-split ?
DC73
Lubbock TX
They also make ducted mini-splits where you can use small duct work to dump air into other rooms.
DC
mike_s
If the mini-split faces the bathroom, such a fan might not even be necessary.
See drawing in original post. Will prob put Mini Split on back wall opposite of garage door. Or might put it above bathroom door (depending on space and access).
rlitman
Long Island
Gotcha. I wasn't sure if that was a window in the drawing, or which wall is the "back".
I guess, what you end up doing depends on how much you care about the bathroom's temperature, and on it's heat gain/loss.
I put a mini-split in my basement, and ran it for heat this entire winter. It was able to keep the whole basement comfortable even on the coldest of days, but the bathroom was a little chilly on some days.
In my case, the bathroom was rather well insulated, being half underground, and with three walls and the ceiling facing conditioned spaces. If your bathroom is poorly insulated, then it might get stuffy in there. If that bothers you, then a fan might be in order.
kj_mustang
Harrisonburg, VA
I would put a wall pass through vent high up in the bathroom wall in front of the toilet. The door should have a gap at the bottom when closed. When the bathroom door is closed and the unit is running, convection will cause the colder air to go under the door and hotter air to be drawn out the vent.
LS6 Tommy
Northern NJ
Great. Let's blow farts into the shop from the bathroom...
There's a reason bathrooms never have return ducts. :lol_hitti
Tommy
JRC3
Southwestern OH
Most closets that size don't have a register.
I'd almost do a pocket door and leave it open when not in use. A pocket door won't eat up any floor space. A piece of door stop applied to the strike jamb gives privacy covering the crack.
DC73
Lubbock TX
Make the bathroom wall 6' high.......
I used this concept in my shop. My ceiling is 10' so I made the bathroom wall 8'. As an added bonus, the exhaust fan in the bathroom can help ventilate the main shop.
DC
b-boy
Buffalo NY
This looks pretty cool.
I have a utility closet in my basement that houses my boiler and water heater. It's about 10'x15'.
Could I use this to draw heat out of that space into the living space? The room gets very hot in the Winter. My concern would be creating negative pressure in the utility space that might pull CO in from the chimney.
Voi
Western South Dakota
I have a 640 square foot cabin with only a single head mini split.
My bathroom & mechanical room (about 100 square feet combined) don't seem to get too hot in the summer even with one of the long walls having southern exposure. We just leave the door open except when in use.
The mini split is about 20' away from the doorway to the mechanical area & the entire space extends 12' further away from the wall head.
Not sure if it matters but the entire area is insulated, even the interior walls, due to winterizing concerns.
gungatim
west mich
I have 3 bathrooms in my house, none of them have registers for heat or AC and they stay the same temp as the house. I think you're overthinking it...
LS6 Tommy
Northern NJ
It's not a lot. The new ceiling cassette systems are very efficient and a great choice for some applications.
DC
I wouldn't sell a cassette to my worst enemy. They drip, have ****** air distribution/flow, are almost impossible to service...
Tommy
finn
The UP, God's country
If you find yourself sitting in the bathroom long enough that a slight temperature variation caused by your mini split is an issue, I would recommend you start a Citracell or Metamucil regiment.
Jackfre
N CA
Your concern is correct. You should have a CO detector in both spaces regardless. Another Tjernlund product is the Combustion Air Enforcer. It ties in with the burner and only provides CA on a call for heat. The Airshare moves about 90cfm. There is a larger unit that can do more but I don't think your space would require it.
Git
S Cal
room to room fan facing IN to the bathroom
Jackfre
N CA
We have a winner. Plus one on the Metamucil!
LS6 Tommy
Northern NJ
NO. Your concerns are correct.
Tommy
That1Guy
Mid Michigan
Bath exhaust fan should pull enough air into room when door is closed.
Agreed!
I was reading the entire thread to see if this obvious answer was mentioned.
Between the bathroom vent fan (vented outside) and the metamucil, :wtf: the problem should be covered - lol.
:bounce:
Notgrownup
Snow Hill NC
Not in more extreme climates, especially if the bathroom has an exterior southern-facing wall.
Agreed, but we don’t know what Mike’s location is. My SIL has a 30x50 Shop with a non climate controlled bathroom and its not that bad...NC can get pretty hot so we’re familiar with the heat.
dcg9381
Austin, TX
Agree with you - it's a non-issue in many places... but is an issue in others.
