grkmec
Need some advice from the HVAC brain trust. Here is my situation:
I am kicking off construction of my new 30' x 58' detached garage (around 1,800 sq ft including bump out). Gable end on 30' and it will have (2) 10' doors. The place will be 2'x6' construction and ceiling with be ~ 13.5' with a raised tie truss - trusses will be 16" OC. The walls will get 3" of closed spray foam (~R20) and I plan to fill the top chord of the truss (2x8) with 7.5" of close cell foam (~R50). There will be no ridge / sofit vent. The rear of the garage will be a gym / play / hang out area. So I am trying to figure out best way to heat and cool. Live in CT.
Here are my preferences / considerations:
- I don't want anything that will be loud. So no modine heater. I have one in my attached garage and that thing is way too loud
- I prefer to avoid having HVAC equipment taking up valuable floor space. I also don't want to build an HVAC / mechanicals closet.
- I would like something that can be controlled via wifi through my phone with an app
- I would like to incorporate some kind of air exchange system (ERV) so I can smoke an occasional cigar during the winter months
- When its cold out, say 20 degrees or lower, I don't want my system to struggle to heat the place to 65. Likewise, if I have to open the garage doors for 5 minutes, I want the system to not take forever to heat the place back up.
So I have gone back and forth with what is best solution. I am considering the following:
1) Go with mini-splits. Given the size of the place, I suspect I would need (2) 30-36k wall mounted units. Would there be any way for these to be linked together or would need separate thermostats?
2) Go with a 5 ton packaged unit that runs on gas + electric. Equipment sits outside and I run ducts up in truss area with registers in ceiling. Downside is that I have ugly looking ducts run up the rear gable of the garage
3) Go with a high efficiency hot air furnace that is like 120-140k BTU that is multi-stage, then hang air handler from ceiling, and have 4-5 ton AC compressor outside.
Anything else to consider? Any advice on what I should do ?
