Jeff
My original lighting idea was terrible. I was using two 4' double fluorescent hanging fixtures in a 20' x 20' shop. Not a bright (sic) idea I know but it was cheap and easy when I initially moved in. So the research began. I saw some nifty shop lights out there at some damned nifty prices too. I read lighting diagrams and performed math calculations. My brain hurts. My ears are starting to bleed.
I wanted something bright, efficient, and hopefully on the cheap. My research wasn't going well. Ideally I should have two 16' rows of double fluorescent fixtures. I figured $150 for the two row setup including bulbs and wiring supplies. Plus the added hassle of changing 8' tubes on the ceiling. I still thought I could go cheaper. Then I read where a member on this forum had 6 existing keyless fixtures in his shop/garage. He changed out the incandescent and replaced them with 100w equivalent CFL's. He doubled each fixture with a Y adapter and two 100w CFL's. Now he has 1200 watts of efficient CFL's drawing only 78 watts of juice. The total cost was under $50. Not bad.
I used his idea, but I needed to add 5 keyless fixtures plus boxes and wiring. From friends in the biz and yard sales I was able to get everything I needed for under $10. Sure, some items were used but in mint condition.
For the CFL's i went with 125w full spectrums. The lights put out an amazing clear light with no yellowing or bluing. Shadowing is non-existent except for the far corners. A 12-pack of these bulbs was $45. My total light wattage is 1125 with a wattage draw of 270 watts.
Not bad for $55 total. Now I've got extra $$$ for that 22" flat screen TV. Shhhhhhhhh, don't tell the wife!
