Tool to mark through a hole with depth
kblee27
Singapore
It's a bit difficult to describe.
But say I have a plastic part I want to hang up. I need to make holes in a wall.
So I need to mark or draw a hole on the wall before I can drill.
But the plastic part has a depth of say 1 cm, with a hole of 4mm.
The problem is I can't insert a pencil or marker through the hole, to draw the point where I want to drill on the wall. Bcuz the fat pencil/marker has a taper and the tip won't reach the end of the hole.
Anyone has a suggestion ? Thanks in advance.
jimmyin3D
southbay, CA
I’m not too sure what you need but the Fastcap long nose markers have a very slim tip to reach into small holes and the like.
88thunder
Center hole punch set?
example:
https://www.harborfreight.com/28-piece-transfer-punch-set-3577.html?cid=paid_google|*PLA+-+All+Products+-+Lower+Sales+Items|New+Products+-+%282%29+Price+%2410-30|3577&utm_source=google&utm_medium=cpc&mkwid=sybr7gXT1|pcrid|318476002941|pkw||pmt||pdv|c|slid||product|3577|&pgrid=63088204546&ptaid=pla-297108743161&pcid=1654049980&gclid=CjwKCAjw0ZfoBRB4EiwASUMdYQAwsu6Yk00MxGW6ytt9kjbrfxEOLDqHzm0r2axSkppf_CG1LOK1bxoCVLQQAvD_BwE
K
kblee27
Singapore
Thank you all for your suggestions and ideas.
I guess I was searching for a deep hole marker.
So I googled Fastcap, found Dixon, Marxman, long nose mechanical pencils, and some other great stuffs.
But they were a bit expensive for the occasional holes I want to mark and drill.
Toothpick and paint - brought me to a simple solution.
I'll try with a cheap nail polish next time. It has an "extended" plastic (thin enough) arm and brush, and paint to mark the surface.
Reese
My local Lowes has thin wooden marking pencils. I don't remember the exact price but it seems they were less than $5.
CrazyTools
Everywhere
I would take a pilot drill such as my 1/64" and just turn it where I was planning on drilling. It would work like a center punch. You can use a 1/8" drill also, as it's smaller than a 4mm hole.
Dave455
Sussex, England
This is a common problem.
I use these ‘Pica’ pencils and pens that are designed especially for that purpose.
These are really well thought out items.
I generally use the pencil on wood and the pen on other surfaces, such as plaster. They offer coloured ‘chinagraph’ leads too, that write on all most surfaces. The pen will easily fit through a 4mm hole!
Bought these about a year back, and wouldn’t be without now!
Here in the U.K. there’s also a gadget that I see a lot of electricians using. It’s a small aerosol with a tapered nozzle. You hold your fitting in place, place the nozzle in each hole and give it a quick squirt. It marks the centre of the hole with a green “X”.
Edit - The aerosol marker is called a “Marxman” - they’re available online.
2oolhound
BC Canada
Put the plastic thing in place and draw a light pencil mark along the top of it on the wall and a little tick on the sides. Now measure down from the top of the plastic thing to the center of the mount hole(s). Next, go to the line drawn on the wall and measure and mark that same distance down to mark your drill hole(s). You also need to make the center distance.
There is no need to mark through the hole.
