2manytools
They have two tools doing a similar job. Both are on clearance for 75% off, I'd like to get one for some future projects, but unsure which is best. I am open to holding off and trying to get an PEX expander if someone thinks that is better. Some of the projects will be regular indoor plumbing, but if the clamp tool worked for outdoor irrgiation I would be incline to pick it up for that alone.
The $350 Pex Crimp Ring tool is down to $88.03 in some stores
The $170 PEX Tubing Clamp tool is down to $43.03 in some stores
I did find out yesterday that the tool I choose could be dependent on the tubing. I am one that would rather invest in a better item now, if there is less expense later, so if I will end up using less connectors with one, that could easily sway me as well.
Thanks for any advice
