After the great feedback here I ended up ordering my Mr.Cool unit from Costco.
I’ll create a new post when the project begins. Thanks to all for the feedback and advice. Stay tuned!
— original message below —
After 5yrs of procrastinating I am finally ordering a mini split for my garage.
Through all of my online research, and going over my needs/requirements with experts and friends, I believe I've found the system that will work for me. Before I pull the trigger I wanted to get advice from others on here - to either support the purchase listed below or suggest an alternative if one should be considered.
My 1st choice:
This unit is sized just a hair over what the experts calculated that I need (don’t want to go any lower per the expert so no need to debate this). I also wanted control via an app/WIFI, which this LG unit offers.
For background the garage is ~2000 sq/ft, mostly 12' ceilings with a section that is vaulted at 18.5', fully insulated including insulated Clopay doors, etc.). It's unlikely I'll run the units all the time (I mainly want them to take the edge off in the summer/winter. However, I have read these units are good at removing humidity so that may be something I consider even if I don't want the garage completely conditioned/heated.
I am open to feedback/suggestions or a pat on the back on selecting a decent unit. My budget was around $5K and this is right at it. My buddies and I will do the install - they have experience and I have the funds
My 1st choice:
- LG Wall Mounted 2-Zone System - 48,000 BTU, 19.5 SEER
[*]2 X 24K indoor LMN249HVT units
[*]1 x LMU480HV condenser - JMF Mini Split Line Set - 1/2" EZ Pull Insulation - Factory Flared
- LG Multi F Branch Box
- Electrical/Breaker, etc.
- A few large fans in the vaulted portion of the garage (open to suggestions)
