Man, that's fun to watch.
Thank you very much!!
It's fun to do too...
That was very well done. Managed to achieve your goal using only green sand and found out what was going on with the runner.
Great progress and next level achieved.
Albeit with a little extra cheek!
Thanks, Guster! I think I can do better if I need to pour a third one.
Great use of the language! Cheek as a verb and noun.
I have always been accused of being cheeky so no one has ever complimented me on having extra cheek.
Will the hot metal "forge weld" itself together since your pour hole froze up and you changed to the large hole? Or will there be a weak line where the two meet? Great video.
Good point, it is very bad practice to pour from two directions although foundries do it occasionally simultaneously. Generally in an extensive pattern yo do get what's called a "cold shut".
In this case the top of the mold was still quite hot and if not fluid, close. I am confident the heat of the direct pour will mix and fuse to the portion already in the mold. I did look for signs of cold shut on the tips of the teeth, where the metal would have been the coolest and subject to not fusing. I saw nothing but would not bet the farm that there are not some weak areas near at the tips of the teeth.
Wall brick in the furnace is 2,600F brick and the iron was about that before removing the crucible meaning the air flow in the furnace had to be 2,900F to over 3,000F to get the iron that hot. That temperature is doing damage to the wall brick. It has been coated with a 3,000F mortar which has turned to glass and there's a little shrinkage of the brick.
Kind of hard to see in the pictures, but every second the furnace is hot I'm puckered up wondering if the wall will fail.
I have 3,000F brick to replace it with, but it's not worn out yet.
Gazza made a great sticker to remind us of Stephen Church aka
1/2 Cup and was kind enough to send me an electronic file which I 3D printed.
Steve sent me the Ford logo. Maybe the sticker would look good in aluminum.
