Chennig
Evening all,
Done some reading that has gained my some good knowledge moving forward. However with a fresh foundation wall and back fill coming on Friday I start to question things.
I noticed on day 2 after inspections and footings where poured, at the end of the day they set and built up the four corners of block. Is this ok to do on the same day as the pour of the footings?
Now that they are done with the walls I am also curious if they should of been tied in with the footings with rebar?
Garage is detached 28x48 located in MN.
Decided to go with a full foundation as I had it in my mind that it would produce a better longer lasting building. Also wanted it to keep the critters out from under as I plan to insulate the slab for in floor heat. Is it worth insulating the entire inside block wall or only the top 1'?
Anything else I should consider before he backfills?
Thanks in advance!
Thanks in advance!
