cutting hard wire
permadirt
my house
whats a good old hand tool for cutting piano wire, spring steel wire etc. i mean what did they use before knipex, high leverage and such back in the day. just curious. something small enough to fit into a tight space but still cut a .125 hard wire. i got plenty of dented up side cutters and dikes because thats all i had on hand. now i got knipex mini bolt cutters- its the best tool i bought lately. they work.
mrjaw14
Nashville, TN
I have the Knipex Mini bolt cutters and they are fantastic. I guess prior to that would have been regular bolt cutters or linemans depending on how thick it was. I think Klein as the blue handle journeyman series that's specially hardened for cutting smaller steel wire.
matt_i
SE Michigan
This is a fantastic app for a cordless angle grinder with thin cutoff wheel, makes very fast work of this. Can substitute zizz wheel on a die grinder or even a dremel. Don't forget eye protection.....
BarryWells
In the mountains
Years ago they'd do a little "scribing" with a screw slot file and snap them off. 1/8 hard wire is hard stuff for a plier that will fit in a small space.
Pull out your best set and try cutting an 1/8 drill bit. Score it a little and it'll snap right off.
seber
Deep East Tx.
This old ****** has cut a ton of piano wire up to .125 dia. It was retired from the factory floor when the operators complained too much about wrist fatigue. It is a bypass cutter with teeth used to keep the wire from popping out sideways. I still keep it on the boat to cut fish hooks in the event of a mishap. Definitely old school.
anetode
I don't know how tight a space you're talking about, but the Midwest MWT-6300 and Channellock 910 are specialized pairs of snips with M2 inserts rated for hard wire. Gedore has a version with HSS inserts, but they're overpriced in the US.
Danglerb
SoCal
Cutting down a replacement spring for recliner turned a couple of my otherwise decent cutters into hillbillies.
matt_i
SE Michigan
Those are not designed to cut solid wire, it will tear them up. They're designed to cut aircraft cable.
So a guy at the plant grabs the Felco aircraft cable cutters out of the shop to cut a tiny padlock off some other guy's locker due to lost key when nobody was around to stop him. I ended up first using the metabo to solve the problem and then ordering a new set of jaws for the Felco, a giant metal chip was removed from each cutting edge rendering it unuseable for the wire rope.
davethorik
Norka, Ohio
As others say, Knipex mini bolt cutter unless you don't have the clearance (I have the original 8" 71 01 200), I see they make a 10" now too. In Knipex I also have a pair of 10" side cutters 74 01 250 and 8" end nippers 68 01 200. I'm happy with all of them, they cut hard material well.
I also have some Klein 2000 series that handle hard stuff too. 2 pair of ironworker-style pliers D2000-7CST and D2000-9ST, and angled 8" side cutters D2000-48.
