I searched online to learn more about the pump shown in the picture above. That company makes quite a few, but the reviews are all over the map.
I wouldn’t mind having the pump remote in the attic (where I can also put a water sensor for safety) to cut back on the noise. Looks like a few operate by having a float attached directly at the mini to monitor the condensation and others attach directly to the mini. I’ll spend some more time on it.
For simplicity I’m still considering just coming down the wall and drilling the drain line through the brick. It is certainly an option that is relatively fool proof.
It's actually a pretty quiet pump... not design to be far away from the AC drain pan... you just have to consider the header or lift of that pump output line (I think that is the term)... there is a limit... means if the pump have a 5' lift before it goes over the hole to outside(down hill) , the efficiency of that pump might degrade , doing more work lifting the water than just pump it horizontally... you'll have to see what's acceptable for your situation.... I think all of the drain pan hole size are same... at least the ones I bought... have the same size hose... for the pump input... yes it have a float inside the unit...
At least the aspen and the ec400 that I bought have 5 terminals... 2 for alarm, 3 for a relay like (NO,NC,Common) to allow you to shut off the ac unit in case the float goes high.... the differences is the Aspen and the EC400 have the pump and the float unit separate as oppose to the one show in this post everything build in...
It should have enough capacity for most mini splits..
EC400 ***** because it was loud, and only have a duty cycle of 3 minutes... supposedly to auto reset when it cools down... but the one I have never resets...it only re-sets when I unplug it from the AC power... and has no warning at this point... that is the reason I had to go get the aspen orange... the one shown in this thread subrasomething brand was not available then...
