Beater
A while back I broke the rear leaf springs on my rig and needed to replace them. I happened to notice after the new springs were installed that my rear drive shaft looked a bit short. It has a ton of compression available, but it only has about 2-3" of extension before it will pull apart. It was already like this (I didn't lift the truck any more than it was already) but somehow I never noticed it being too short.
I decided I needed a spare shaft in case I break the current one. I've gone through a few in the last couple years, so there's no doubt that this one will get beat at some point.
Here's the beater with the new 3" rear springs installed:
So, on to building the spare...
A dude broke his at last year's East Coast 4Runner Jamboree, so I gave him my old spare and brought home his broken one:
Then I cut out the really bent/twisted/broken section:
I did some measuring (cruising around Lowes with my digital caliper) and found that the ID of my shaft was just a freakin' hair bigger than the OD of 2" rigid conduit, so I picked up 10' of conduit for like $34:
I decided how long I needed my shaft to be and I cut the conduit to length, and slipped it in:
The broken shaft is about .050" wall, and the conduit is about .150" (kinda hard to tell the real difference 'cause I didn't file the conduit clean inside after cutting it with the chop saw). Where the new shaft is sleeved, it's nearly .25" thick:
I drilled some holes so that I could plug weld the sleeves together:
Since the conduit is galvanized, I ground it all off in the weld area:
Then I clamped it up in a homemade jig, using my bed rail and some 3/16" angle iron, so I could align the yokes/u-joints as closely as possible:
Once clamped up and as straight as possible, I tacked it in place, checked it again, and fully welded it. Sure it's not balanced, but it'll get me off the trail and/or get me home. I didn't get a fully welded pic, but it pretty much looks like this...
