454ragtop
Found this Manley press on CL, been posted for quite a while, started at $75, then dropped to $55. Why so cheap you ask, seller said it had a blown seal. I wanted it and was watching for a while, just couldn't find time to go retrieve it. Surprised to see it still available, I made arrangements to get it Wed. Yesterday I decided to see where it was leaking, after getting somewhat of a sticker shock at what seal kits were going for. Pleasantly surprised to find an external leak where the pump pressure piping entered the ram body. Kind of a PIA to take it apart, but after cleaning the threads, recut the external thread with a die, and reassembling with Loctite Hydraulic sealant, no leaks, and works like a champ. Info, or even pics for these seem to be hard to come by, Google search didn't turn up much at all. Any idea what the valve on the top of the ram housing is for? May flip the bed or table channels over because of the bends in the flange (How'd they do that?). Not that simple though, will need to cut the table raising cable arms off and reweld on the other ends of the channels. Looking at the tag, I'm guessing it was made in 1951.
