Summit engine dollies were mentioned in this thread:
http://garagejournal.com/forum/showthread.php?t=57017
These ones:
http://www.summitracing.com/parts/SUM-910057/
So I bought three to try to clean up my garage (S+H was the same for 1, 2 or 3)
I assembled 2 of them. On one of them one of the holes did not line up:
I had to trim the mounting tabs to clear the 168 tooth flex plate:
The motor mount brackets were about 1-1/2” inches too wide, so I had to loosen the bolts on the cross brace to get the motor mount bolts in. I’ll shim those later. I thought the nuts welded to the cross brace to store the bolts when not in use were a nice touch.
Final results. The wood blocks are because that one is a 4.3 L so it’s too short. The 153 tooth flywheel clears with no modification.
So for $33 they have cast iron casters and roll easily. Minimal tweaking to make them work, for the price I can’t complain. I would buy more if I need them in the future.
My favorite engine pulling adapter:
These ones:
