46MGTC
I just realized that we forgot to rough-in the electrical for a future mini-split HP in the garage. I need to get this done before insulating the walls. I've got no probblem running the 220 line but I'm unsure of how to install the outside disconnect box now that the vinyl siding is up. I'd rather not cut up or remove the siding if possible.
Can I just run the wire through a hole in the wall into the back of the disconnect box and use a siding "light block" mounted on the vinyl siding to hold the disconnect? Is it OK to just use NM wire through the wall into the disconnect?
I noticed that the directions for the HP (LG 18K btu) gives a wire size of #14 AWG but spec. a 20A breaker. I thought that #12 was required for 20A? Since I have some #10 left is it OK to use this on a 20A circuit?
Thanks for any help.
Dave
'46 MGTC
'59 MGA
Dave
'46 MGTC
'59 MGA
