Best tweezers
Grant Gunderson
Bellingham, WA
I do a bunch of Mountain Bike suspense worn and wed a high quality set of tweezers for ball bearings, gaskets etc. what do you guys recommend?
matt stott
Boston, USA
Dumont is the brand name- Dumostar is their high end line. Nothing better out there.
BUT, for small ball bearings I like to use a cheap brass tweezer, and file them for specific purposes.
mr.lemons
UK
ChrisLS8
I use a German Brand called 3 Swords. Made in Germany and look to be nicely made. No complaints here
Skin
Boston
Solingen. Tried some Dumont and, like most things that shove Swiss made in your face, I think they're massively overpriced for what you got. Tips mangled and misaligned in short order like some $2 drug store junk.
rshadd
Doylestown, PA
For holding small parts without finger pressure, I like these cross-over tweezers by Knipex
These Tweezers by Tweezerman are also good, but picking ball bearings with them might be challenging. Great for picking out splinters though.
Davefr
OR
Dumont's are the best but I'd take a different approach and get some needle nose pliers with fine (ie tweezer like) tips.
There's almost nothing better then Swanstrom S331E's (w/mild serration pattern) for what you're suggesting. (tips measure .06" X .03")
measuredtwice
USA
What's "best" depends on the application. The Knipex posted above would probably be good for your application.
Either you were using fakes or you were using the wrong tweezers for the wrong job. There are different styles and alloys used for different purposes, ranging from surgery to handling electronics components. Surgical forceps are delicate and will bend easily but they are not at all comparable to $2 drug store stuff. There are LOTS of fakes marked "Dumont".
Dumostar is a brand name of the steel alloy, not the tweezers.
"Dumostar
This Dumont patented alloy is composed of C, Cr, Mo, Mn, Co, Ni and Si. Dumostar is more elastic and more resistant to corrosion than the best stainless steels. It is also perfectly compatible with human tissues and is resistant to mineral and organic acids as well to salt. Although slightly more expensive than other alloys, Dumostar is 100% antimagnetic and is resistant to sterilization temperatures of up to 500°C.This is the most cost effective and appropriate alloy for laboratory use."
G
Grant Gunderson
Bellingham, WA
Thanks guys. Already own a bunch of Dumont’s surgical grade stuff for camera repair. Just ordered some of their more industrial ones as well as the Knipex to check out. Those Swanson tweezers pliers look great but man the cost insane.
M6erfan
'Merica!
^^^These are nice
Danglerb
SoCal
Half a dozen from cheap to good, depends on the job. My wife has a blunt tip pair of tweezers for plucking hairs that I've found pretty handy for a lot of tasks where I don't want to poke myself of some underlying item.
