Black Iron Pipe To Galvanized Pipe
BigGarage
Just south of Detroit, MI.
If I do one more project this year it will be to replace the old galvanized steel gas lines in the house. I have an underground line that runs out to the garage though. It's not been used in many years but I do have a 30-40000 btu heater out there and I use propane (separate propane heaters) in the winter for heat if I'm working out there. I may want to use the natural gas heater one day instead and save trips to the propane store.
Is there an acceptable (codewise) method for coupling the new black pipe to the old galvanized pipe?
Dennis
bob15
Northeasten, CT
I would run the copper tubing inside PVC pipe. This will protect the copper tubing.......
Of course, check with your local reg's first. It was legal for me.
LS6 Tommy
Northern NJ
I agree about the steel underground, replace it with rolled copper.
Check your codes. You can't use copper with natgas if it contains more than .3 grains of Hydrogen Sulfide per 100 cubic feet of gas unless it's treated for that use.
Tommy
Stuart in MN
Minneapolis
As you may have guessed from the responses so far, there are number of different types of gas line possible but it will depend on what is common practice in your area, as well as what the local gas company requires. Ask them.
isolate it & do a 100psi test on it .
Natural gas lines typically are ~2psi coming from the street, and 1/2 psi or less on your side of the gas meter. 100psi seems excessive.
mrobins297aaa
south east michigan
I agree that just creates leaks that you would not normally have
HoosierMark
Southeast IN
In the city where I live the local gas company (city owned) sells the contractor or homeowner the length of yellow flexible gas line they need and will install one fitting on it for free (no labor). Will do both if you are sure of your length. Their theory is that safety is important and provide the residents with what we use at cost is a good idea.
BigGarage
as said above, but, I would question the condition of the buried steel pipe before you get anxious about using it.
The gas valve from the house to the garage is open and has been for probably 50-60 years. I have never smelled gas out there. It's about 20' from the house to the garage and I have a garden there so much time is spent in that area. No gas smell ever. If I ever smelled gas I could shut it off in the basement and decide what to do. I was just trying to avoid running a new underground line under a sidewalk (3' wide) if I could.
Dennis
gmwelder86
Oakdale , ca
Standard test for low pressure gas pipe is 15 pounds for 15 minutes. Residential gas operated at les than .5 psi. Testing at 15 pounds your going to find any issues if you have them. Now medium and high pressure welded systems that’s different.
If the old system is working well and doesn’t leak why mess with it. I’ve found once you start messing with old black pipe systems weather it’s gas or water, once you start you might as well take it all the way back to the meter.
mrobins297aaa
south east michigan
Dennis
Here's a easy way to check it.
Make sure no gas appliances are running.
Now go out to the meter and mark with a pencil the position of the needle on the most sensitive dial......come back in a half hour and see if the needle has moved at all........if it hasn't moved your good.
if it has then start turning off the valves on the individual appliances to see if you can locate it.
edit: now if you happen to have any standing pilot appliances you will have to valve them off for this to work
mrobins297aaa
south east michigan
Are you telling me the connector fittings are the same? I thought black iron gas lines were tapered some and may have needed something special.
I do not know anything much about gas lines. Thanks.
Dennis
The pipe and fittings are all the same, there are plenty of systems out there that have a mix of galv and black pipe.
BigGarage
I understand and mostly agree with you but there is a scary looking gas valve down there in basement and I'd like it gone. I could just remove it and put a plug there and leave it. The valve most likely controlled gas to the old original steam furnace with radiators.
The valve looks like an extra large gate valve. I'm sure it was gas rated but its just at the end of a line coming down a few feet from the ceiling and it just needs to be removed. It does have a plug at the end of it but it scares me just looking at it.
I would replace all of the piping back to the meter so I'm clear on that. I just wanted to know if I could leave the line going underground to garage and tie into it.
I just went down and looked at the valve and noticed that the installers of my boiler (in January) used black iron pipe to connect to the original pipe. Unless my eyes are playing tricks on me.
I would have a qualified person do the work, I would not do it myself.
Dennis
mrobins297aaa
south east michigan
one more thing, years ago in Detriot there was a code that you couldn't use galv. pipe on gas lines.
Not sure why, one theory was that the galv. would flake off and plug the orifices on the appliances.......which I always found it hard to believe.
But a much more likely reason was that back in the 40's and 50's all the water pipe was galv. so they didn't want someone cutting into a galv pipe thinking it was water and they were actually cutting into a gas line. So it made sense, black for gas, galv. for water.
BigGarage
Here are 2 pics of the gas valves in the basement and one pic of a union on the line going to the garage.
If the knowledgeable people don't have a problem with these items I may leave them alone.
Dennis
BigGarage
A boiler installer about 15 years ago told me the same thing. He would stop by every so often and get an extremely small stainless steel needle from me to unplug orifices with. He was 75 and knew his stuff.
Dennis
mrobins297aaa
south east michigan
well maybe there is some truth to it but you can't prove it by me, now days there's a lot of galv. pipe and fittings being used on gas and I have not heard of one service guy saying he's running into that problem.
lots of places don't even sell black pipe and fittings anymore only galv.
buzzworth
Louisville, KY
Galvanized should not be used for gas. The valves are suspect for gas, look like globe valves. Even old gas valves are quarter turn.
And the use of a bushing in the valve would not meet code here.
(Former supply house sales)
