This is the current condition of the garage floor in my house. I'd prefer to put epoxy on the ground than tiles.
What would be involved in repairing this?
What size is your garage? Depending on how big the garage is, you may be doing an awful lot of grinding. I am assuming you will want the floor to be level when you are done, so you will need to grind the entire floor down to the same level as you grind the pitted areas.
You can grind the pits and then fill it in with a patch and the patch area will stick to the floor without flaking off? I am sure you know infinitely more about this than I do, I was not aware you could do that. I had thought the patch area would be really thin and consequently would have a tendency to flake off, obviously I would be wrong. I learned something new today.Grind, fill pits, grind filled area level.
You don't have to grind that low, could be grinding forever!!![]()
Your going to grind the whole thing 1x. Make a slurry patch, trowel over the pitted areas. Once cured, grind the patch flush. The slurry patch is epoxy/sand. Not cement
Could you please suggest a product?
