Where is the capacitor? Should there be one?
Cahark
Dayton,Oh
I picked up an old black and decker heavy duty 1/3hp bench grinder the other day. I’m guessing that it was made in the 1940s or 1950’s. It runs ok but I knew it could use a new cord, bearings, and a coat of paint. This brings us to today.
When I removed the cover from the bottom of the base, I was surprised to not find a capacitor. There was a bracket for one on the sheet metal access panel, but the capacitor itself looked to be bypassed and missing. The grinder seemed to start fine, but I can’t help but belive that there should be one here.
-Does anyone have any insight here?
-Anyone willing to remove their base access panel to see what’s on theirs?
-What is the proper size capacitor?
-How would I connect it with 3 leads coming off the motor?
-Is there supposed to be a capacitor at all?!
Thanks in advance,
Cahark
ttpete
Dearborn, MI
It's probably a split-phase motor. They don't need a capacitor to start, but they won't start under load.
C
Cahark
Dayton,Oh
That’s possible, but don’t split phase motors have capacitors? I don’t know enough about the subject.
C
Cahark
Dayton,Oh
That wiring needs some attention.
That looks like it will make you a great grinder,when you get it fixed up!
I plan to heat shrink all of the leads off the motor, new switch, and make sure there’s a good ground. Thanks for the encouragement, I’m excited to use it.
DenisG
Milwaukee
TWO leads go into the motor - one is hot and the other is neutral. You can connect it directly to a power cord to try it out, but the hot wire should have the switch breaking that connection. The ground wire from the power cord should be connected to the base for safety.
No capacitor is used on this one. The motor is a squirrel cage motor and the bench grinder is a "Special 6":
https://www.garagejournal.com/forum/showthread.php?t=336177
http://vintagemachinery.org/photoindex/detail.aspx?id=14268
nelstomlinson
Interior Alaska
Does it start without a capacitor? Yes? Then you don't need a capacitor.
Edited to add: if it wouldn't start without a cap, you could spin it by hand before you close the switch, and you'd still be OK without the cap.
C
Cahark
Dayton,Oh
If i understand correctly there are three types of capacitors. Start, run, and start run. I think some need one, both, or a combined capacitor. I have started motors by giving them a spin To diagnose a start cap, but never a run cap.
C
Cahark
Dayton,Oh
This motor has 3 leads to the stator. Not two. I was able to verify when everything was torn down. Does that change things?
nelstomlinson
Interior Alaska
You might be right. My rotating machines class was in 1984, and it wasn't a strong point. I don't remember anything but the start cap, but after so long, I might not remember what I forgot.
If it starts and runs as is, I'd use it as is.
bpjr
Florida east coast
If it runs I wouldn't worry about it. I checked my boat lift motor by taking the cap out of the circuit. It ran fine wired directly without a load. It needed a start cap just to get it spinning under load.
Fcvapor05
If it runs don't 'fix' it.
If it needed a capacitor and didn't have one, it 100% would not start.
