Hi guys, I need to wire up an outlet for my planer. I just want to make sure I'm doing it correctly. Whats a little confusing to me is that it has three wires and if a neutral is used.
Now do I install a double pole 15amp in the panel and using 10/2 (I had this laying around) attach both black and white to the breaker and ground to ground? No neutral needed? The three wires coming out of the motor switch is somewhat confusing me. If not this way, how should it be done?
I have photos of the motor plate, switch, and plug (I'm switching the plug to a 250V I bought at HD) on planer.
thanks
thanks
