Designing a new garage
HoundOfDoom
Hi,
We're moving to a new home in Q1 / 2020, but we're not finding anything with a garage I like.
So I'm just going to have to build my own.
Can anyone direct me to sites or tools I should look out to rough out a garage that would fill my needs? I'd like to work out some ideas before I speak with a developer.
Thanks
astroracer
Mid_Michigan
What is the use of the building?
How big are you thinking?
This site right here can give you some good direction when you give us some info... :)
Mark
NUTTSGT
Northern Central Ohio
Eight years as a member and you have not looked through the Garage Gallery section ? Plenty of great ideas with a ton of pictures.
kd3pc
Northern Neck
first stop would be the county/town zoning folks and ask what can be built in your desired location. And any restrictions on the build.
That would be the AHJ, authority having jurisdiction - as to what they will permit, how much the permit costs, inspections needed and so on
Are you looking to be in a HOA/POA/PUD - if so get a copy of their documents and read them before you sign anything. Anything.
boiler7904
NW IN
Might want to check if the town's you're looking to buy / build a home in allow a detached garage. My town does not allow detached garages at all and attached garages have a square footage limit. HOAs and garages tend to not get along in general - avoid that **** like the plague.
OneOfEm
This, certainly.
I found an inspiration here, laid out a design in Sketchup from the pictures and the site where the shop was going, then sent my design to the engineer who did the full plans.
Since you won't be building yourself, you could bring photos to the developer/contractor showing what you want.
It was a process.
vavet
Ashland, VA
If you're buying an existing house, make sure the house is situated on the lot in a way that would allow construction of your shop later possible/economically feasible. Certain things to keep in mind:
slope of the land
septic fields (my house has the primary and has to have a certain amount of land set aside as a secondary, meaning I can't build on that chunk of land)
well
setbacks from property lines
HOA restrictions (my HOA allows detached garages, but if the roll-up door faces the street, it must be 30 feet behind the rear foundation line of the house. If the roll-up door does not face the street, then it must be behind the rear foundation line but the 30 foot distance is eliminated).
utility lines/easements
HOA might require the exterior of the shop to match the house, which if vinyl siding isn't a big deal. If it's brick then it gets more expensive, at least where I am.
If you decide to build the house and the shop, then it might be a little easier to get HOA approval and things can be situated to your liking from the start. You just have to be vigilant because contractors, house building companies, subcontractors, etc don't always communicate well. We built our house about 4 years ago, but not the detached garage. I don't know how many times I had to remind various people within the same home building company that there was a plan to build a detached garage later so we needed that to be considered when the house was sited on the lot, when the propane tank was buried, etc.
H
HoundOfDoom
Thanks Astroracer, I'm working that out. Has to be at least 4 car bays + shop/bench space. Probably won't have room to go larger.
Good point on the HOA Kd3pc. I have long awful experience with them.
Boiler, understand, will check. I saw a couple of properties in the area w/detached, but who knows how that came about. One good thing is we're talking Texas here, so I get good vibes on local authorities.
Thanks OneOfEm. I have sketchup experience.
Thanks VaVet, lots of good points.
Thanks Polexican, appreciate the support.
Ddurrett896, are you on the right thread?
Thanks Firebirdparts. Will chalk out the garage on the site - I saw that on a film about McDonalds where they optimized their system.
MushCreek
Upstate South Carolina
While your checking zoning/HOA rules, check on overall height restrictions. I see a lot of threads on here about people wanting to install a lift in a 10' high building. My choice was to build on acreage zoned agricultural, and they seemed a bit surprised that I even pulled a permit. I'm a fan of barnplans.com both for their looks and for the large, usable loft space. I built a 28X48 with a 12' ceiling downstairs and 8' headroom in the loft. It is a 27' tall building, though. Their website is a good place to peruse for ideas and inspiration.
PNWguy
Near Grants Pass, OR
I've been drawing my house and shop on paper, and am really happy with the process.
I have a portable drafing board similar to this: https://www.amazon.com/dp/B004CYWN5K/?tag=atomicindus08-20
I use graph paper, a scale straight edge (most of my work is in 1/4" or 1/8" to the foot), and a few drafting tools. I also have tracing paper, so I can overlay things like the lighting diagram on the drawing.
I photograph these and send them to the contractor who turns them into blueprints. We've done the vast majority of our development that way, and it works well.
Overall, I found it to be much faster and easier to edit than Sketchup. I'm not drawing the blueprints, so I don't need 100% precision. I just need it good enough to get to the contractor.
Have fun.
NUTTSGT
Sketchup.
folks, all he asked for was tools or sites. Nothing about codes and hoa police.
Actually, I think some considered this last sentence in his post.
Before he wastes his time and money speaking with a developer, he has to know his limitations where he is building or if he's going to need a variance.
Nobody wants to get their hopes up, spend time doing so and getting their bubble burst after months designing.
