So my builder and his HVAC guy think that I won't be happy with a Mini-Split system. Mostly because Michigan is cold for 4-5 months out of the year and the mini splits can cool great but won't heat as well. They suggested a giant Garage heater, installed with gas run from the house for $2500. Then I can buy two window AC units for use in the summer. Still not sure...
But we've got Holes and Lumber!
I didn't see any PEX down before the concretedid I miss something?
I bet you're going to wish you made the lean too 3X bigger. Just from experience.
How many VW's you own?
I can cool my 30x40 with one 24k btu window unit. Ceiling height is 13-15.5 ft high , spray foam insulation , I'm in NJ
What a great build. I am looking at building a something close to this. Did you go with a kit or company or sub contract out everything? Is you don't mind me asking what is the ballpark figure you have in it so far? I am thinking about doing shingles and siding as well.
It don't take long to get money invested in a nice shop.
On your dog run, maybe find some plastic coated wire about 2ft high and lay it underground of the dog run so he can't dig around the perimeter.
Did you say split bus? These are my babies. 1963 15 window, and a 1966 21 window deluxe with sunroof. MMMMMMGOOD![]()
awesome, i am actually adding a 40x54 onto my mechanic shop and i am thinking the same thing. I got some old pioneers about the same size, havent used them for years but remember them shaking knick nacks off the wall.
Well we are about 90% finished with the build. Still need doors but Loft is done, all electrical run and tied in to the house. Should have the inspection done today and then I can get cracking! WooHoo!
Here you go man! Loft pics.
I like the loft , is that extra sleeping area or what?
I don't have a Notch, but its a type 3 Wagen I just received from Puerto Rico. Check out my site for the story on that one. I also have a Ghia that I just got a couple months ago, thinking about using the motor out of it for one of the buses.
Concrete is sooo smooth when its new. Skateboard approved!
JMO, but the more light the better. My 24x32 had (8) 8' double florescents, now (7) since I had to remove one to install my lift. I'm looking to add more very soon.
