Work bench question
Scout3918
Southern Indiana
I am going to build a wood work bench
It will have a 3/4" think plywood as top.
Should i put some kind of sealer on it? I just be doing doing normal house/garage things on it. I have a HD steel one for other stuff.
Thx in advance
gunguy
Currituck Co. NC
I would consider doubling the thickness of the bench then topping with Masonite (hardboard). When the Masonite gets too beat up, replace it with a fresh piece.
Makes for a stiff, flat, and smooth working surface.
Jim
BOOT
Lots of flooring options I've read about make good tops.
Sunosauno
Bali
Make sure you have at least approx 2" overhang on all sides to permit clamping.
Marc
+1
ezover
3rd rock from the sun
I used 2x4, 2x6 flat under my plywood to make it sturdy, stiffer. Wish I had thought about the 2 inch over hang.
Never thought about sealing it, what type of product would you use as a sealer? I just figured I would replace the top if it got to beat up / dirty.
Jackfre
N CA
Boiled linseed oil (BLO)
QwikKotaTx
Seabrook, TX
I used MDF over ply on mine and attached it with screws from below for a cleaner look. Ditto on the overhang. I use cardboard on top of the MDF when lubing something up or cleaning a gun or fishing reel to avoid staining but it happens. Don't overthink it.
dfiler2
NW Minnesota
I used masonite over plywood also, works great. I get about two years before I flip the sheet over or get a new one. I built it with an edge around it so the masonite sheet drops in, I put a few dabs of silicone in to hold it tight.
Stuart in MN
Minneapolis
Another vote for a Masonite top. It resists fluids and stains pretty well as is, but a coat of varnish on top of it won't hurt anything.
Piggywutz
PA
X4 on the Masonite. It’s what my father uses on his bench and when I built mine, I followed suit.
Alchase
Harrah, Oklahoma
I used 3/4” ply covered by Masonite.
Has been perfectly fine for over five years. If it gets damaged, a few screws and replace top for a couple bucks.
OneOfEm
+7 on Masonite (tempered hardboard).
Mine is two layers of 3/4 MDF topped by a solid core door topped by the hardboard. I wrapped the whole assembly with solid lumber trim so that the hardboard is flush with it. I then covered the hardboard with a couple coats of water-based poly. It's held up very well. It will probably last 4-5 years more before I have to flip the hardboard.
I use it primarily for woodworking. Wood glue pops right off of the poly.
