Gnfantic
GM everyone, electrical is almost done so looking to insulate the garage. I know spray foam adds strength to the structure and does not absorb moisture (closed cell) so I am trying to go this route but it is about 35% more then open cell
So my questions to you guys...…
Both companies I called for estimates stated to me the rafters do not need venting (I was going to install the baffles). Because no moisture will get in there due to the foam. But what about the Sun blasting on the roof? I thought HEAT was also a concern..... Comments???
2-) For the roof rafters, should I go for closed cell??
3-) These guys are charging roughly $3.50 a sq ft for closed cell at 3in thick. Should I look into do -yourself kits???
thanks!!
thanks!!
