Corner work bench or straight?
sk8louisville
Louisville, KY
Hey guys, what're your thoughts on a corner bench vs a straight bench (across the back or side wall)? I put a corner bench in my old shop but it seemed like the corner area was just kinda wasted space.
Yay? Nay? Any pics of what you guys like to work with/on?
Thanks!
MFolks
Springfield Mo.
I built a rolling 6 ft workbench with caster brakes,making cleaning so much easier. A grizzly 1 3/4" butcher block top with a factory coating is what I have.
ItsNemo
Canada
Really depends on the overall garage layout...the extra depth in the corner can be handy though.
tarmy
Nor Cal
Ftw...
67carl
California
As mentioned above it probably depends on your layout. My situation dictated a U shape and I've found the corner to be convenient. Only pic I have available right now shows it in process.
matt_i
SE Michigan
I placed my welder and a jib crane in the corner to serve the L-shape. Kinda wish I could have a walk around though for better use of the space, it was just too tight for 2 aisles though.
APEowner
Sunny, New Mexico
Corners are hard to utilize efficiently. They can be a good spot for big things that don't move like a large upright air compressor. When I built my NY shop I built an L shaped bench and the corner ended up being a catch all for clutter until I put a PC I that spot. That worked out well.
Mr. Roboto
New Hampshire
I built a corner bench. 3 years out, and the verdict is still out on weather not I like it or not heh. I have a 3 x 6 "island" bench on wheels that I use 99% of the time. My corner bench just becomes a catch-all for junk most of the time.
klassenl
Southern Alberta
Yes. Hard to make corners efficient.
I had/have room for a "L" but I made mine straight. Some one told me that flat horizontal areas attract junk. He was right. If I get bored some day I will make my fixed workbench up against the wall smaller since (believe it or not) I don't have problems with storage.
BigGarage
Just south of Detroit, MI.
Thanks!
When I built mine I used it quite a bit to work on. Now, it's just a place to store things.
Definitely put it on wheels. My floor slopes rear to front and sides to center a little so all 6 of my 4x4 uprights are a slightly different length to make the surface level.
Dennis
sk8louisville
Louisville, KY
Thanks. My buddy stopped by yesterday and swore up and down a straight bench is the way to go.
"You need a place to put your chop saw". Of course he'd say that, he's a woodworker. :)
RKA
Inside corners are difficult. You’re not doing anything that might require infeed or outfeed for items with any length. Storage underneath can be difficult to access and the depth only ensure the back of the cabinet turns into “deep” storage. But sometimes a garage layout requires it, so it’s certainly better than no bench at all. But if you have a choice, the straight bench is a little more practical. Leave one side open so you can walk around the side...put your vice there.
JRC3
Southwestern OH
My old one was a corner. Will do another corner when I get around to it.
Only real problem is the corner becomes a catch-all.
ekimneirbo
Kentucky
Thanks!
You should build what will work best for you and your type of hobby. There are a lot of nice benches posted here and the builders should be justifyably proud of their results. In my case, I need workbenches that are functional and strong. I need to be able to set heavy dirty things on them and weld grind and pound to my hearts content. Since your avatar shows a bunch of rods, I assume you fool with motors and old cars too.
My benches aren't pretty, but they are strong and extremely function friendly.
The old gray bench was built over 30 years ago from 2x6s and then boxed in with some doors. Holds a lot of stuff. Got a Stainless steel top at an auction and put it on there for working on dirty and greasy engines and stuff. Wipes right up when I'm done. Handy for paint mixing too, as I spill things.
Later I added the builtin engine stand. It goes completely through the bench for strength. Can be removed when not needed. Put a small I beam overhead that makes raising engines or anything an easy task.
The old roll around Craftsman bench was $75 off Craigslist. Got tired of always having a standard wrench and needing a metric. I built the pegboard with some steel braces behind it and then drilled and tapped them for 5/16 threads. The wrenches are arranged in ascending size no matter whether they are metric or standard. Got the wrong wrench...2 steps,put it on the pegboard and grab the one right next to it. Works great when I'm using my 2 post lift. Need a different socket...look at the wrenches and see what the next larger one is. I could buy a beautiful Snap-On box if I wanted to, but then I'd worry about scratches and dents and keeping things perfectly organized. This way I usually have several different wrenches of every size hanging on the pegboard, and I don't care what brand they are. I can roll it anywhere I need it, even outside. Much better than any high zoot box.
The thing is that there are many ways to make workbenches. I have a lot of other benches in my shop besides the ones posted. The pallet rack workbenches can be built with 10' or 12' crossbars and make a really nice workbench with lots of storage space that would go unused. Check out any local auctions, especially industrial auctions for used racking at affordable prices. The thing you want to do is decide what will work best for you and how can you make it do more than just be a bench.
b7labelle
A vertical air compressor goes in the corner.
I have been thinking about this a lot this afternoon...want to run a 20’ workbench along my garage wall. Not sure wth to do with the corner, also have another workbench on the adjacent side of the wall.
A spot for a vertical air compressor seems like the logical option. However for me, I’ve decided my air compressor is taking up a hell of a lot of floor space in my single car garage....and realistically, how often do I need a air compressor? I can pick up a 1/2” electric impact and a battery powered air pump and go on with my life. For indoor work, I use a pancake compressor anyways. For others, maybe a large verification air compressor is worth the floor space. For me, I think I’m coming to the conclusion I’d rather have more benchtop and shelf space.
cspcrx
Phoenix, AZ
I think it really comes down to your space and how to best use it. I used to have two work benches in mine and it just felt like the space was not being used as best as it could. This is what it looked like before.
44754487290_294568446b_c.jpgUntitled by Victor M, on Flickr
46520305782_e1a7653c9c_c.jpgUntitled by Victor M, on Flickr
Then I built a purpose built bench for my space and what I was trying to store. Took 110ft of steel but I created this. So much happier with the amount of usable space I have and the storage.
46236991335_20d0ec3a74_c.jpgUntitled by Victor M, on Flickr
40186227953_d9f4273396_c.jpgUntitled by Victor M, on Flickr
Jackfre
N CA
If you are uncertain build two benches. One longer than the other making it into the corner. Should you be unhappy with the L-shape you can pull the short end off. I have a pretty good sized space, but things move around depending upon the project(s) at hand.
cspcrx
Phoenix, AZ
There is a shelf under there for some boxed tools, like drill and impact set, air nailer, etc. Yes my pancake compressor fits in there. If you had a small vertical or horizontal it could fit in there easily. I have a large vertical on the other side.
67CarGuy
Outside Boston, MA
I am also a fan of the air compressor in the corner, as long as I can get or plumb access to the drain valve. I may end up stacking my shop-vac above my compressor in the near future, although I realize that it will make changing the vac. bag a bit more of a chore...
Alternatively, it becomes storage for stock, as someone else already mentioned.
Of course, the other alternative is a circular shop, then you don't have any corners :lol_hitti
jives
Central NY
My workbench is considerably more cluttered now, but the corner provides a place for a chair -- serving as a desk.
Falcon67
Merkel, TX
I'm a fan of the air compressor in a closet with lines run as needed. :) Mine is a 60 gallon upright installed in a small insulated closet to cut the noise level. Drain is plumbed through the wall to outside.
Daubs
Eastern Nebraska
I went straight mainly due to location in my shop.
One thing I highly recommend is a movable workbench. I made the movable lower to work on heavy projects...and was able to make the stationary workbench higher for detail work.
View media item 95375
