Is that wear on the TiN, or oxide from the bolts transferred to it?
Very normal, the TiN layer is like an oxide layer. Just because you see the shiny gold going away doesn't mean that the hard layer isn't still there, although is does eventually wear off and has little benefit on a socket like this anyways
I’ve got a few of that style of Hazet bit. Most of them have the same discolouration in the coating. If you wipe them down regularly I find you minimise it, which suggests that at least some discolouration is deposits from the fastener. The really well used bits the coating is definitely worn, but this only seems to be cosmetic, and I can’t find any real wear on the bits.
If it bothers you, Hazet also offer the ‘one piece’ bits, at least in 1/2 inch drive
I asked an engineer in a local manufacturer, whos company installs new drills at the start of a shift and replaces them at the end, if I should splurge for the coated drills. He said most users only need HSS, either plain or black oxide coated. He said, "You know what that TiN coating is for? It's to lift money out of your wallet."
I've heard this line repeated several times. I think it applies to other tools too.
Bill S
