Yes, the grip is very similar to that of the Vessel. This screwdriver works very well with its 72 teeth has a very soft touch, I even dare to say that I like it better than the PB Swiss .Nice! Reminds me of the Vessel ballgrip
I have one of these too, but didn't know they were also sold with bits, unless you are talking about the double-ended shanks I saw on Amazon Japan.I bought only the screwdriver but it is also sold with bits.
I use bits of PB Swiss Tools and they are perfectly inserted in the screwdriver Anex.
Any more details on SK11?
I've come across some of their stuff on Webike and amazon.co.jp and assumed it was just another Taiwan rebrand.
Lobster/Lobtex 90th Anniversary UM36XB adjustable. Next to no play as promised by "G-Less" and already proven itself capable as it was the first thing within arm's reach.
I usually check amazon.co.jp or Rakuten Global Market (i-tools or Kouguyanopro). Frankstools carries them too, but their pricing is likely double what you'll find on Rakuten.
Anex screwdriver ratchet nº 397
(Oh, one other thing I should mention is that the Wera Rapidapter works great with the Anex handle. It clicks into place and provides a nice metal locking collar that firmly holds all bit types except for double-ended.)
Here are my results with various Japanese stubby ratcheting handles combined with Wiha power blades.
The ball grip Vessel was by far the worst. Because it holds bits with a split ring that had contracted in the smaller diameter portion of the bit but wasn't touching it, the bit moved in and out a couple of mm without resistance and also wobbled side to side. It was also quite difficult to remove the bit. I ended up using pliers. I would not use this handle with any bit that did not have a long anvil with straight sides.
The other Vessel has a deeper cavity and its little ball bearing was pressing against the second hexagonal portion of the bit, so it held the bit firmly. This handle unfortunately has much more back drag than the Anex or the other Vessel.
The Anex held the bit almost as well as the Wiha handle did, thanks to the long second hexagonal portion of the bit which pressed against the internal ball.
I encounter situations where the Wiha handle/bit combination is awkwardly long, and the Anex is a nice alternative.
I found out today that there are a number of different Rapidapters, with some of them long enough to click into place.
Here is the packaging for the clear Vessel handle, just in case anyone is curious.
I think there are some diff standards for 1/4“ bits, I seem to remember the Japanese is different; May be wrong though...
-Some sweet KTC clip lifters that I wish I found out about years ago.
Metric Tech
Well that would explain it...
BMW started using the "bi-hex" plugs back in '07, in their N54 twin turbos. Typical of BMW to go to a non-standard size but I'm sure the engineers back in the motherland had good reason
Of course Ford has their 9/16" size plugs...
I just caught this post and thread a bit by accident, but I have an N54 engine, and I'm just now realizing that I may not have a socket to get the plugs out (and I did buy OE plugs for a future change). At any rate, do you know if a chrome 12 point 14MM socket would work, or does it have to be a special thin walled 14MM. Also, is the "bi-hex" work with a 12 point socket, or is it a special shape. I saw 14MM Chinese thin walled deep well sockets on eBay for as little as $3.00, shipped free, but was wondering if you're aware of any inexpensive high quality thin walled sockets for N54 engines?
I really wish Vessel sold their Crystaline drivers in sets. You got the biggest boys I see!
Bahco make ratchets with the direction switch on the handle.
Bacho is made in Japan? I thought it's Taiwan.
Depends on the tool and when it was made. I have bahco tools from Japan, China, Taiwan, Spain, France, Argentina, Germany, Italy and even USA.Bacho is made in Japan? I thought it's Taiwan.
