Matias: one GJ member on here had high ceilings in his garage and he not only put the racks sideways so he had a full work area underneath them on one side of his garage, but he also hung up a big flat screen on a wall and put a sofa up on one of the racks for he and his buddies to watch games on.
i'll see if I can remember which thread it is cause unfortunately it was a couple years ago and i'm subscribed to over 4000 threads.
have a great weekend.
BTW I just received some AWESOME chocolate from SWEDEN that was shipped out from FINLAND you might like. do you like milk chocolate and black licorice?
here's the candy bar and we had to order 10 so they wouldn't cost us $10 for each bar.
pretty tasty
Thanks Drives, I was also contemplating about the idea of having a sofa higher up, but I think it will not be feasible. As on the right side of the garage I have the lift and so need the space, and on the left side I have the one higher cabinet (I regularly slap myself for buying a cabinet that is higher than the rest
Oh yes, I do like that, and here in Finland the salt liquorice is called salmiakki. There is a new chocolate which was launched some time ago, with turkinpippuri, literally meaning pepper from Turkey, but is something like spicy salt liquorice. Maybe I should send you one so you can have a taste
Hello!
I have done some work at the chocolate factory that make these bars in Upplands Väsby outside of Stockholm. the company I work for have the global facility management contract for the owner of the factory. One of the bonuses is that my company runs the stafv shop where you can buy chocolate for a very discounted price
I think that kind of bonus would be my ruin
I like your French Cleat idea. It will be very convenient to have a system that allows easy change in that space. I also love that Workbench!
Thanks! Need to continue with the woodshop soon, but first I need to finish this side of the garage. More on that below
We have had exceptionally nice and warm weather, around 25C which is 77F. Due to this, I went on my bike for my work trip. There is a lot of activities now ongoing on the fields, and a lot of tractors on the road.
In anticipation of setting up the cabinets next week, my amazon order arrived brinning me my new ladders. At around $150 they were not cheap, but damn are they good. As I will be using them a lot in the garage, I think they are the best safety update I have done.
Garage workbench
I decided to save some money, and instead of ordering a table top from Ikea, I wanted to use some old lumber I had and the two sheets of cheap basic mdf which I had saved. They came as tops for pallets containing random stuff, so you know they're the cheapest ones you can find. But they are heavy.
I decided to use nearly the whole length, just trimming the edges, as these were 270cm long (106"). Then just had to narrow the width.
Here just getting the top of the frame straight, then measuring each leg to have perfect height everywhere.
To attach the pieces of the frame together, I used pocket holes. I had ordered this Kreg jig some time ago, really handy. I must have paid double or triple what you pay in the states...
Attached the pieces together with pocket holes, then painted it all black and attached it to the wall. I will screw a couple additional screws still. It is attached to the studs.
For the top, first thing to do was to attach a strip on the bottom. This was glued and screwed in place.
As it will be visible even from below, "I" painted it the same black as the frame. The rest of the top was just painted with rattle can black.
I then cut and painted the supports.
The smaller edge is against the support, the bigger one against the table. I marked the supports with some screws, to know the top of the support, and which is which. They are all jsut slightly different lengths. Also on the top the angle is 90, but on the bottom it is a couple of degrees bigger, due to the slope on the cement floor towards the drain.
I predrilled some holes with countersink, to attach the second sheet of mdf later on. Also, there are some additional holes on the strip, to secure that also to the second sheet.
And here it is in place. It's still missing the top sheet, which needs to be painted and attached. Was going to glue and screw it, but will skip the glue. This way I can change it later on if I want to. Also, it is easier to manage the top when the pieces are separate.
As you can see, the design includes hinges (will still add 4 hinges to it), so that it can be stored away if needed. The hinges are on the bottom, and placed so that the weight of the top is on the frame, not the hinges. With the supports at angle, it is easier to move the toolbox in and out, and also keep the floor clean underneath.
