MadeByMiller
I recently picked up a Rockwell 31-710 6x48" belt/disc sander. The specs for the motor on it are:
-3 phase
-230/460 input voltage
-1.5 hp
-5.4/2.7 amps
-3450 rpm
I don't have 3 phase power, so I'm looking to convert this to run off of single phase 220v power with a vfd. I have tried doing my due diligence to research what I need, including searching this forum and the sticky. I'm still unsure of exactly what unit to order. It's my understanding that you should focus on the the amperage, not the hp of the motor when choosing the proper size of vfd - and double the amperage. In this case I would need at least a 10.8 amp vfd then correct? I've seen a lot of people like the TECO brand units (I know to avoid the cheapo Chinese brands). Here is a 10.5 amp TECO vfd - https://www.vfds.com/3hp-230v-teco-n3-vfd-n3203csu - is this what you would recommend? $350 is more than I would like to spend to get this sander up and running, but I don't want to cut corners either. Please help me out and set me straight here, some examples of models that you think would work in my application would help as well. Thanks in advanced folks!
-3 phase
-1.5 hp
-5.4/2.7 amps
-3450 rpm
