RYOBI introduces the 18-Volt ONE+ Power Caulk and Adhesive Gun Kit. This tool features over 500 lbs. of push force to handle higher viscosity material with ease and can apply more than 200 tubes of caulk on one charge. The all-metal manual plunger rods with hook ends allow users to quickly change out tubes of caulk, while the durable gears and carriage frame help insure tool longevity. The 18- Volt ONE+ 1.5 Ah Lithium-Ion Compact Battery delivers fade-free power for maximum performance and has a lightweight design for reduced user fatigue. The 18-Volt ONE+ Charger features Dual Chemistry technology to protect battery cells, maximize battery life, and conserve energy. Best of all, it is part of the RYOBI ONE+ Worlds Largest 18-Volt Tool System*. Backed by the RYOBI 3-Year Manufacturer's Warranty, the ONE+ Power Caulk and Adhesive Gun Kit includes (1) 1.5 Ah Compact Battery, (1) 18-Volt Dual Chemistry Charger, and an operators manual.
Caulk Gun: Variable speed selector lets user adjust the discharge rate to control the bead of caulk
Caulk Gun: Switch lock helps prevent accidental start-up
Caulk Gun: Center balanced handle for increased user comfort
Caulk Gun: 200+ tubes of caulk per charged battery
Caulk Gun: On-board puncture tool to break tube seal if needed
Caulk Gun: Improved GRIPZONE overmold for optimum grip and user comfort
Battery: Extreme weather performance to withstand frigid weather conditions
Charger: Compatible with all RYOBI 18-Volt ONE+ Batteries
Part of the RYOBI ONE+ Worlds Largest 18-Volt Tool System*
3-year manufacturer's warranty
Includes: (1) P310 18-Volt ONE+ Power Caulk and Adhesive Gun, (1) P189 1.5 Ah Compact Lithium-Ion Battery, (1) P118 18-Volt Dual Chemistry Charger, and operators manual
*Stem Pack Style Battery
