Need a Thin 19mm open-end wrench
giants
California
I'm trying to remove the banjo bolt on a fuel filter. To hold the fuel filter while doing this, I need a 19mm open-end wrench. A flare nut will not work. My open-end wrench (Great Neck) is too thick to fit. I measured the space in question and it's about 9mm in thickness.
A combination wrench, open-end wrench, or Crescent wrench would be fine.
Just to be clear, the thickness/thinness is when measuring the end when the tool is resting. The attached photo shows "S" which is what I'm talking about
Any brands you can recommend?
iWrench
USA
I have the Capri Tools set of thin wrenches and they work great for me. The metric set is 6-19mm, $45 on amazon.
Jazz1
Thunder Bay On.
Grind a pawn shop wrench to fit. I have altered a few wrenches for specific purpose. Cheap and quick jet than searching for one
619DioFan
San Diego , Ca.
I have the grip brand thin wrench set from northern tool ( 25.00 ) if you want a whole
set it is good quality. otherwise I would just take any 19mm open end and grind it down to fit.
bargainhuntingking
The Amazing Pacific Northwest
I bought a set of these in Japan last year for about $15 US. These are ultra thin wrenches from TOP tool. Someone is selling a set on eBay now for $25 w/ free shipping. “TOP CU-5000” . The largest wrench in the set has a 19mm & 21mm. A worthwhile set...when you need them, you really need them. I used them in fact today getting in between a narrow opening on a metal furniture castor bracket. Indispensable.
RKA
I would go with the thin adjustable. Every now and again this need will crop up and as long as it’s a low torque app, one tool should cover the bases. If you need something that can withstand a little more torque then a thin wrench set (like the top tool mentioned above) might be in order. But usually you don’t need to put much torque on them.
toolmutt
Texas
Home Depot now carries a set of thin wrenches under their Husky brand. I can't attest to the quality, though.
chevy302dz
NE
I recently purchased a set of these and can say the quality seems quite good, especially with regards to the amount of force you can apply to such a thin wrench.
larry_g
oregon
I agree with this. A wrench from the store is just the starting point to make it into what YOU need. This is why grinders are important to have.
lg
no neat sig line
bpjr
Florida east coast
I've ground down old wrenches to make them thin. Also bought a really thin bicycle wrench at walmart. Park is the best but I think wm had another brand that I paid $6 or $7 last yr.
kctyphoon
Jersey/Staten Island
plinker
Northern Wi
The VIM/Capri/Matco thin wrenches are pretty good. I've had occasion to put quite a bit of torque on mine and they seem to be holding up just fine for wrenches that I figured would really need a warranty.
