Small vac hose attachment?
Ign
Butte Peak ND
Are there any adapters to fit tiny hoses or attachments (like crevice tools or something) to standard shop vacs?
I just discovered I need to **** a broken injector clip outta a 2V Triton spark plug hole (not my doing) and I can't be the first person to wish for something like this.
In the past I've cobbled together ****** setups with vac or fuel line and tape, but it's inefficient and I'm ready to buy something.
I could also build something on the lathe but FFS if I can save the time I'd prefer to do other things with my life right now....
I
Ign
Butte Peak ND
Ok, now you might be onto something with this micro kit shown on that page!
https://www.homedepot.com/p/RIDGID-...:rt+dln:{562931}+qu:{ridgid+micro+vac+kit}:qu
Annoying thing is while it repeatedly says it works with 1-1/4 hoses I can't find the diameter of the attachments, ie could I slip 3/8" or 1/2" rubber hose over it for a flexible mini suction tube....
But for $15 worth a shot!!!!!
Thank you so much!
And still open to other suggestions
MFolks
Springfield Mo.
For clothes dryers,there's a "Lint Lizard,Hurricane",and I suppose you could add a smaller hose to it for tight spaces.
Black300zx
Elkton, Md
I assume it's a plastic clip? Can you see it? Is it big enough that you might be able to heat up the tip of a piece of steel rod and get the clip to partially melt to it?
