This side cabinet/locker was pretty disappointing.
There is no mechanism to keep the door in an open position. it just swings freely, so if the whole assembly is on an uneven floor, like this one must have been, the door will just try to partially close itself. This position is where it seemed to want to return to based on this particular floor.
The four drawers on the bottom of the cabinet are nice and sturdy, but when you grab the black plastic grips you see centered in the middle of each drawer they pull right off due to the amount of force it takes to try and get the drawer moving from its locked position.
They are literally just friction fit pieces of plastic that say 'ICON' on them. The proud owner of one of these lockers will have to take them off, apply some type of adhesive, and put them back on if they want them to stay in place.
The inside of the door has the same type of slot system for mounting various holders as the main box has behind the main worksurface. It seems like a sturdy enough system, but unlike a traditional peg board-style system, you'll obviously be locked into buying only ICON accessories to mount in those slots. The bottom accessory you see here is as low as you'd be able to mount anything, as it slightly interfered with the top drawer as is, so any lower it would definitely cause an issue with the drawers opening.
