kest874
Just have a few questions as I've seen different things reading around on the internet.
I've attached a couple pictures, we're in the process of having a 24x24 garage built. I feel comfortable with doing the electrical work but have a couple basic questions I can't seem to wrap my head around.
You can see the propose panel location in both attachments. My question really is about getting wire ran horizontally on the 2 walls where the trusses are.
The walls are 9' should wire be run up through the top plate then across the truss and back down to outlets in the wall? Or can you run wire horizontally through the studs and then down to the outlet.
I'm planning to use quad boxes evenly spaced out with 2 circuits in each one. The walls will be finished with insulation and covered with osb.
