Wiring thermostat to contactor.
Flyingdutchman1488
Canada
I have a homemade boiler, it has two 4500w elements. I want to wire a line voltage thermostat to a contactor to control room temp with in floor heat. What is the correct way to wire it?
Kevin Essiambre
Ottawa, Ontario, Canada
How do you plan to circulate the water (glycol?) Through the system? Are you planning on just using convection?
All in floor heating systems I've ever seen use a circulating pump that's controlled by a thermostat wired into a controller that will also control the boiler.
Sent from my SM-G920W8 using Tapatalk
fitter30
Peace Valley,mo
Radiant floor heat can't be controlled by only by boiler temp. First water temp only runs 5-10* over room set point. Second it the mass of the floor. Once the floor is heated up it will stay warm along time and it takes a long time to heat heat up so the room temp will be at extremes. Best to use a stat that has a floor sensor made for radiant floor heat and control water temp by boiler water temp control.
F
Flyingdutchman1488
Canada
There is a circulating pump. I know how to wire it. Also the boiler is controlled by an aqua stat for the glycol temp. The thermostat and contactor I’m asking about are for the room temperature.
walta
Dutzow Missouri
What do you want this thermostat to control, the boiler, pump or a valve?
Walta
htmdude57
Hudson Valley, New York
Are there no diagrams on the boxes or instructions that came with the thermostat and contactor? If you don't have the boxes or instruction sheets that came with them, you could try googling the brand and part number of the parts and you can most likely get the instructions.
