Cursed_Mongo
Hi Everyone - First post here, so please be gentle on the roasting. I know this is a long post.
I have a very generic question and need some feedback. I know there is not a one size fits all answer, so I am just asking for everyones opinion.
I am looking at buying my first (and hopefully last) real piston air compressor. I am thinking a 5 hp would be big enough for what I will be doing like tire inflation, impact wrenches, cut off saws and wheels, and air chisels. I want a verticle tank for space and I do not need it to be portable. For power, I have 230V single phase 40 amps available. The budget is pretty open. I just want to buy one that will work and last.
Now, where I start getting fuzzy is on what I should look next, or what is important to look for. I've seen compressors that vary in CFM, tank size, stages, pressure, and starter types.
CFM it seems the single-stage ones put out more CFM, but cannot build the pressure. 2 stage compressors build the pressure but don't have lower CFM. I know the higher pressure is more "stored power" in the tank, but will a higher CFM compressor offset the need.
Tank size - it seems 60 & 80 gallons are the 2 sizes available. Do I really need 80 gallons?
Pressure - Most of my tools require less than 100 psi, do I really need a 2 stage that goes up to 175 psi?
Starter - I can find compressors with a switch starter and magnetic starters. I assume the magnetic starter is better because it costs more, but what is the advantage and is it important?
Drains - Is the ball valve okay, or should I upgrade to an electric drain? I feel like the electric drain would help me remember to drain the tank, but what about wasting air and longevity?
Thank you in advance!
