Will this sheet metal bend tear?
Ottawa, Canada
I'm looking to make a sheet metal part that has a bend on a 45 degree angle to the main axis. If I don't relieve the ends, do you think it will tear?
I'll be using 5052-H32 aluminum in 11 gauge. Using a press brake. I guess I should use some scrap pieces to see what will happen. I can make a bend relief, but the flat shape is much simpler without it.
4 FN 27
Minnesnowta
3D ISO View would help a ton.
I assume it is a Hem???
You will get a little tearing. It helps that you will be 45° to the gain of the Material.
You can buff out the corners on a Scotchbrite Wheel or file them.
Ottawa, Canada
Yes, it is a hem. Here are a couple isometric images.
Thank you for your feedback.
4 FN 27
Minnesnowta
Nice...that shouldn't be too bad (the tearing) with an open Hem.
Now forming it will be a little tricky with that last hit being so deep.
Looks like something I would do...:)
Edit: Forgot to mention if you buff the edges where the Hem will be it should not tear as much.
Ottawa, Canada
My plan is to bend it to 110 degrees and then "flatten" it into a teardrop hem and see how much bend back I get.
I just don't want to get a crack that will propagate. Although I guess I can always drill it out.
rwa2004
Western PA
I design a lot of these types of things - and then I get yelled at.
You give up some strength when you go to 3003AL, but you will get much lower risk of tearing. One of the shops I work with will frequently tell me that I have to use 3003 instead of 5052 or else they won't do it because of tearing.
hawkeye2
I’d anneal it first. Mark the bend line with a marker heat the backside until line fades mostly away, and let it cool
