Superseado
Ok guys, new to the forum. I put up a 24 x 30 pole barn last year. Wood structure with metal skin. I have metal on the ceiling with blown in insulation. I am getting ready to do the walls. I plan on framing in between the post for ease of hanging sheet rock. The biggest question is what to do or especially not do for insulation. There is a ton of conflicting information out there.
I am not going to use spray foam. Just way to expensive.
My original plan was just framing the studs and using R19 bat. But i am now hearing the bat should not touch the metal. Also hearing there should be a radiant barrier.
So now i am leaning towards attaching 1" foam board with radiant barrier to the girts and using R13 between the studs. I will be DIY spray foaming along the base of the metal skin to seal that up from critters and air flow.
With all that being said does anyone have either success stories or failure stores similar to my plan?
It makes sense to add that i am in central New Jersey. Plan on only heating when i am in the building nights/weekends. AC is unknown yet.
