scooterbum46
I've got lots of Dewalt 20 and 60 volt tools, so when I wanted a 1/2" battery impact, I bought a DCF899 kit. Reading the instructions (like on the third day, you don't think I do that first do ya?) I ran across the following paragraph and warning:
"Variable Speed Trigger Switch (Fig. A)To turn the tool on, squeeze the trigger switch 1 . To turn the tool off, release the trigger switch. Your tool is equipped with a brake. The anvil will stop when the trigger switch is fully released. The variable speed switch enables you to select the best speed for a particular application. The more you squeeze the trigger, the faster the tool will operate. For maximum tool life, use variable speed only for starting holes or fasteners.NOTE: Continuous use in variable speed range is not recommended. It may damage the switch and should be avoided"
I've read that a number of times, all I can assume is that after a bunch of warranty claims due to switch failure, the money people and the product engineering people came up with a solution - put a CYA in the product guide. I mean, it's a variable speed tool, but don't use it that way very much or you may damage it?? Now I really understand AVE's comments about value engineering in consumer level products .
