Oxy/acetylene cutting tip question
Tracs
Manitoba, Canada
Hello,
I have a nice Harris torch and big tanks of Oxygen and Acetylene I got a year ago. I have never used it until last week.
When I originally bought a tip they gave me a #2. I never noticed. I was trying to cut some 3/8" steel plate and was having a heck of a time. It would start cutting and then stop. It didn't matter if I went slow or fast.
I now have a #0 tip.
Would using the #2 tip with 40psi Oxy and 7psi of Acetylene have been way too much for the 3/8" plate and that is where my problems were coming from?
I don't have anything to cut to try out the #0 tip. Was just wanting some confirmation.
Mr_fixit
Rustylvania
I'd use a 0 tip on 3/8". I think the only size tips I ever used were 0 and 00. so my guess is maybe. My guess is also that you need to learn the proper technique of heating and then cutting.
royce
fairbanks ak
Tracs,
A #2 Harris tip is designed to cut 1" through 2" plate
A #0 is designed to cut 3/8" through 5/8" plate
If you google Harris tip chart it will show the tip sizes, gauge settings and travel speed.
Hope that helps.
Royce
gearhead1
NC
Royce,
I’m just curious since you do a lot of fab work, do you use propane or acetylene?
joe49
Tonica, Il
Clean the #2 tip, pressures are on high side for tip and the tip size is larger than needed for 3/8'' but should work. If you still have trouble you likely need practice.
dr_clyde
Holland, MI
Yeah, #2 is for sure a bit big for that thin of steel.
I run a #0 or #1 for general shop cutting tasks.
I also much prefer acetylene vs propane. Acetylene is still relatively cheap and I use the torch often enough for fine soldering and brazing work that its not worth the effort to swap out for propane to just save a few bucks here and there.
If you're doing a TON of heating, propane is capable of producing more BTUs/hr than acetylene for a given cylinder size, as there isn't a withdrawal rate limit on propane. The TEMPERATURE of acetylene is hotter, but you get a higher VOLUME of heat out of propane.
For just general shop use, there isn't enough of a cost difference to warrant the hassle of propane IMO.
Kaizen
New England
Op was this a new setup or used? If used maybe hose or regulator causing drop in pressure randomly. Also I’m assuming you have had the tanks standing for at least a few days right?
MoonRise
A Harris #2 6290 cutting tip is way oversized for cutting through 3/8" plate.
As mentioned, it is sized to cut through 1-2" thick plate.
Pressures for a #2 6290 tip are 40-45 psi O2 and 10-15 psi acetylene.
It is going to flow 20-30 cfh of acetylene, so you should run that sized tip with AT LEAST a 140-210 ft3 acetylene cylinder (or the equivalent capacity of manifolded cylinders) to stay under the 1:7 acetylene flow safety rule.
It is also going to flow 20 cfh of O2 for the preheat flames, and jump to 180-195 cfh when you hit the cutting lever.
If you have a two-piece 6290AC (two-piece heavy-preheat) tip, the #2AC tip calls for 40-65 psi O2 flowing at 161-252 cfh when you hit the cutting lever and acetylene pressures of 8-15 psi with 18-36 cfh of acetylene on the preheat flames.
That means a minimum acetylene cylinder size (single or manifolded) of 126-252 ft3 for the 1:7 acetylene flow rate safety rule.
If you have a different model cutting tip that you were/are using (Harris makes Victor-style stuff too), then you would have to look up the pressures/flows for those tips.
T
Tracs
Manitoba, Canada
Hoses and regulators are new. Complete torch was refurbished by a welder supply company. Tanks have been standing for a year.
T
Tracs
Manitoba, Canada
I switched to a #0 tip.
I don't know the capacity of the acetylene tank. The Oxygen tank is medical grade from a buddy and has a tag that says it filled to 3.37 m3 (120 cu ft).
I don't know the science behind gas withdrawal, but I hope I won't have a problem with the size of tanks I have.
ItsNemo
Canada
Acetylene isn't something you should just hope you won't have problems with...take the time to learn. The 1:7 rule means you shouldn't draw more than 1/7th the tank capacity.
See:
https://www.harrisproductsgroup.com/en/blog/2019/august/what-is-the-1-7-acetylene-rule.aspx
harley jim
Cleveland Tn..........out in the sticks
Looks the same size as mine. Like others have said tip is a bit large. You need to heat your metal until it is red before you hit the oxy lever. Practice will make the difference. Get some scrap and practice.
Sent from my LG-LS777 using Tapatalk
MoonRise
That acetylene cylinder looks like a 75 ft3 one.
Absolutely read and understand the 1:7 rule for the acetylene withdrawal rate.
