I've inherited an hold house plus shop, both plumbed with cast iron. I'm attempting to add a bathroom to the house and need to tie in the toilet drain to the main stack. I have the venting and water supply worked out, but the only way I can figure out to tie in to the main drain requires a 180 change in direction. This change could all be in the vertical direction if needed as it is in the crawlspace. If I use 2 long sweeps to make this direction change, does anyone foresee any issues? Would vertical or a less severe angle be best?
No code and no inspections, but of course still want it to drain properly.
