Mooresville Garage
JBlack002
Greetings Garage Journal viewers. I’m making my first post here to share the garage build completed in connection with a new home my wife and I recently built. As an introduction, my name is Jim, I retired after a 35+ year career in Houston, Texas and recently moved to the Mooresville, North Carolina area (north of Charlotte) on Lake Norman (in “The Point”). The home was the culmination of a two-and-a-half-year process of finding a lot, designing and then building the home. The home was a custom-build and began with a blank sheet of paper. The plan from the beginning included my desire for a garage a car and garage enthusiast would appreciate (at least my vision of it). In recent years, I’ve come to enjoy detailing my cars; therefore, the garage design was focused on providing a place to detail cars regardless of weather conditions. I also enjoy working on motorcycles and doing basic maintenance on cars and wanted a workshop area for those purposes. I’m glad to share the results here. Key elements of the garage:
- 1,720 ft2, attached
- 4 car bays, 1 golf cart bay, workshop area
- High ceilings (12-1/2’ in front and back, increasing to 16’ in the middle section)
- High lift garage doors (made by C.H.I.), powder coated aluminum frame, ½” insulated and tinted glass panels, 10’W x 8’H on car bays, Liftmaster 8500W Jackshaft WIFI garage door openers)
- Porcelain tile floor with center drains (floor slopes toward drains)
- Moduline Pro II cabinets
- American Custom Lifts Model M1-6.5 single-post car lift
- Wash bay on center “utility wall” that houses the equipment (Kranzle K165 water pump, Mosmatic 2-piece folding boom pole and wand, CR Spotless water deionizer, BigBoi car dryer, 2 Cox 30’ electric hose reels, VacuMaid Garage Vac Pro w/50’ hose, Prier hot/cold hose bib, Eley hose reel with 75’ garden hose, Moduline closet and fold-down workbench)
- Compressed air system (Jenny J5A-60V air compressor, Prevost piping, fittings and valves, 2 Cox 30’ air hose reels)
- Lots of ambient light via glass garage door panels and windows/skylights in the workshop.
- Saylite square and linear LED pendants for primary lighting (2 x 8’ Square pendants over wash bay and lift, 2 x 4’ square pendants over other 2 bays, 6 x 8’ linear pendants in workshop and at front of each car bay). Each light fixture provides 4,000 kelvin and is dimmable. The Saylite fixtures are supplemented by 17 x 5” LED can lights throughout the garage.
- Wall cladding consisting of a stainless-steel linen lower panel (supplied by Rigidized Metals) with a 3’ row of “Megawall” aluminum slat wall above the lower panel at certain places.
- Full HVAC
- TV and Audio via Savant home entertainment system
I’m very happy with the result. We moved into the house in late June and I’ve enjoyed using the garage and especially the wash bay. Everything worked out as planned and I can’t think of anything I would have done differently.
One pleasant surprise was the relative lack of overspray from the wash bay. I had planned to install a curtain (suspended on track from the ceiling) that would be pulled around the wash bay when in use. I’m happy I don’t need it.
It took a while before I decided on the porcelain tile floor. I originally intended to use Swisstrax plastic modular flooring (15.75” squares that connect together). I really like the Swisstrax qualities of a clean look, easy maintenance and ease of installation. If you change your mind, it’s easy to take up and do something different. However, as the garage evolved and took shape, some challenges emerged with Swisstrax (in my opinion). The main difficulty is the shape of the garage, with a two 20-degree doglegs (the main one being in the garage center). I couldn’t get comfortable with how the Swisstrax would merge at those junctions. The angled pieces would join with no connection. Swisstrax offers some options to secure the junctions, but I couldn’t get the clarity I wanted on how secure they would be. Besides the junction issue, the design of the garage continued to gravitate towards a more upscale appearance and porcelain tile was the better design match. The tile I selected is from Walker Zanger with a 5 PEI rating (the hardest) and was designed for commercial use, so it conforms with the minimum dynamic coefficient of friction (DCOF) rating of .42. That means the footing is very secure, wet or dry. I’m glad a went with porcelain tile. The look is phenomenal. It’s expensive to install, but if done right, porcelain tile is among the most durable materials you can have in a garage.
As I mentioned, I detail cars in the garage and lighting is very important. I spent a lot of hours looking at lighting options. I ultimately found Saylite and really liked their pendant LED lights. I was blown away by how good they look and work. The Saylite fixtures are supplemented by 5” LED can light. The ambient light in the garage during the day is good enough that lights are optional. At night, the LED lights put out just the right amount of illuminance on cars that I’m detailing, without being too much. A nice feature is a motion detector at the entrance into the house. So, for example, if you’re taking trash from the house to the bins in the garage, the motion will turn on the can lights to light a path to the bins.
Selection of the wall cladding was also a long process. I wanted something to give the garage an upscale look and provide a barrier for moisture coming from the wash bay (although that hasn’t been a problem). The Moduline cabinets have a stainless-steel countertop. I thought extending that theme throughout the garage might make sense. I didn’t want something too flashy and over the top though (e.g., no shiny diamond plate). I found a company Rigidized Metals and really like the different stainless-steel textures and finishes they offer. I selected the “linen” texture for it’s rich and nonreflective look. In certain places, we added 3’ of Megawall slat wall above the linen stainless-steel. It matches the theme and adds the functionality of using the wall space to hang things and keep clutter up and off the floor.
I use the car lift primarily for parking (to get another vehicle in the garage) and wanted a lift with a small footprint. American Custom Lifts makes a single-post lift that’s perfect for my application. My electrician spliced into the power supply on the lift and added an electrical outlet affixed to the center post. I use the outlet to hook up battery tenders for cars parked on or below the lift, which avoids the need to run extension cords across the floor.
I use the compressed air primarily to run pneumatic Rupes polishers. The Jenny compressor has been great. With a 60-gallon tank, it has a lot of range and only takes a couple of minutes to recharge.
My vision for the garage was influenced by viewing content on Matt Moreman’s “Obsessed Garage” YouTube channel, website and Facebook group. If you’re familiar with Matt, you may understand. He’s a garage and car enthusiast who has a lot of experience searching out the very best in products and equipment. My vision would have been much narrower if not for the information shared by Matt (and it kept expanding as he pursued new projects). For example, I would never have considered putting a wash bay inside a garage without seeing Matt do it in his. I decided to add a compressed air system after watching Matt install a system in his garage. It opened my eyes to how special a garage space can be, if you have the passion and desire to make it special. Some of the equipment in my garage is commercial-grade and somewhat hard to find since the manufacturers don’t market to the consumer. e.g., The pressure washer (Kranzle) is German made. The boom pole (Mosmatic) is Swiss made. The compressed air tubing and fittings (Prevost) are from a French company. The air and electrical reels (Cox) are American, but not heavily marketed. All are very high quality. Matt introduced me to these products and watching him install the equipment in his garage gave me the ideas and courage to do it in mine. As an added benefit, I was able to source and acquire the equipment through Obsessed Garage and Matt was very helpful consulting with me throughout the project. I feel fortunate I found Matt and Obsessed Garage just as I was beginning the project. It was great timing!
The garage turned out fantastic and exceeded all my expectations. I hope everyone has a garage that puts a smile on your face the way mine does every time I go in it!
J
JBlack002
More pics...
J
JBlack002
More..
J
JBlack002
More...
amkluttz
Concord, NC
Greetings from Concord! I work just down the road in Huntersville. Beautiful place you have there and seems very functional.
Matt's original garage build and his build at his new place is on this site somewhere as he is a member.
mybigwarwagon
Vale, Nc
Not sure how you drive in Mooresville. I get there a couple of times a month to pick something up. Traffic is horrible til 1am then lightens up till about 4am.:lol_hitti
There are some amazing cars up there though. Makes my poor old Suburban look bad.
J
JBlack002
I stay away from I-77 as much as possible! The traffic where I live isn't near as bad.
zjohnson1
Newnan, GA
I see 4 bays but only 2 Ferrari's taking up a single one, what else is in the stable? Amazing garage, looks very well planned. Never seen a light setup like that before but it's got a really cool aesthetic with the clean modern feel of the space. Really makes the cars pop
J
JBlack002
My wife’s BMW X3 and my Honda Ridgeline. Thanks for the comments.
J
JBlack002
What color is the 488? Looks too dark to be Azzurro California (?)
The 488 Spider exterior is Blu Mirabeau. Interior is Blu Medio/Nero with yellow accents. Here’s another view.
jkeyser14
(rural) Maryland
Can you help me find my jaw? It just fell and hit the floor. Damn nice garage. I love the angled corner to create an open area for tool box access. I would love to see shots of the house too.
J
JBlack002
Appreciate the comments. Here are a few photos of the house. Mostly done, except for unfinished landscaping.
alberto
That second set of pics shows the color better. Beautiful car inside and out. Good color choices.
ford33
Chicago, IL. USA
Beautiful home and garage. I worked as a consultant at Lowe's corporate offices for 16 months a few years back. After work, we would occasionally rent a pontoon boat and motor around that lake. That's a beautiful area of the country. The NASCAR hall of fame is down the road in Charlotte.
Boosted1
Georgetown, KY
Beautiful home and garage as others have said.
How did you choose Mooresville while living in Houston?
I like the Mooresville area.
I see a dirt bike stand and pics on the wall.
Do you also have a dirt bike?
J
JBlack002
Neither me nor my wife are from Houston and we always expected to move once we were through working. My wife’s mom and sister/family live in Richmond, VA, so we focused on a mid-Atlantic location. We considered several options and ultimately chose the Lake Norman area (Mooresville, NC, just north of Charlotte). We built on a lake-front lot in “The Point” development. Beautiful area that’s close enough to Charlotte to have convenient access to the international airport and other big city amenities. We love the area!
Riding motocross was my favorite hobby for many years while in Houston. Great stress release to get out on the track and just focus on riding (and not crashing!). Loved building modified bikes. Those pictures are the last 2 bikes I owned while in Houston. A 2015 Honda CRF450 and 2016 KTM SXF350. We sold our house in Houston in 2018 and moved into a rental in The Point while our house was being built. Didn’t have garage room for cars and bikes, so sold the bikes before we left Houston. Miss them every day! Would love to get back into MX here in NC. Only problem is the closest tracks are 2+ hours away. I’m working on new hobbies, detailing cars, boating and playing golf (and hoping a closer MX track opens some day).
Boosted1
Georgetown, KY
Thanks for the reply.
Your logic for the area makes sense to me.
I have also owned a CRF450 and a KTM350X-CF.
The CRF was a mistake for my skill level. The KTM was nice.
Mike.ASC
East coast
I like every part of your design especially the cabinets and the overall brightness of the color scheme
J
JBlack002
Thanks for the comment. I stressed for awhile on whether the blue cabinets would be too “loud” and might not compliment the other gray-toned elements. I also wondered if the stainless-steel wall cladding would look gaudy. It all came together better than I expected and I wouldn’t change a thing.
Dad Of 5
Originally North Jersey just moved Charlotte, NC
Absolutely Beautiful home, garage and cars. I relocated to Waxhaw (south of Charlotte) last year and am renovating a house in Cornelius to sell. I am poor but love cars - if you didn't know there is a big Cars & Coffee in Charlotte the first Saturday of the month with some amazing cars.
hobie1dog
Cornelius,NC
Exquisite house and garage, you are one lucky man. Lived in Mooresville for 13 years, now live in Cornelius below Exit 28 , there's a cars and coffee in Cornelius too.
